Old 05-18-2011, 02:49 PM
ddenton ddenton is offline
Vehicle: 2002 Dodge Ram QC SLT Sport
Trim Level: SLT Sport
ddenton is on a distinguished road
I put a TB spacer on a 1993 Dodge Dakota 3.9 V6. It had better throttle response but don't recall improvements in MPG. I put a TB spacer on a 1993 GMC 5.7 V8 and really didn't notice any improvement. I buying a 2002 Dodge Ram 1500 this weekend. This thing I plan to do is the TB modification like the high performance TB sold.
Old 05-21-2011, 11:13 PM
stevo629's Avatar
stevo629 stevo629 is offline
Vehicle: 2003 Dodge Ram 1500
Trim Level: sport
Color: flame red
stevo629 is on a distinguished road
I tried everything possible to increase the mileage in my truck. The very best thing I found is to not step on the peddle! I spent $ on air intake,dual exhaust kit, throttle body spacers and functional Ram Air hood. Very little difference. We all bite the bullet. Best not to spend on all these things and put the $ towards buying gas!
Old 05-25-2011, 11:02 PM
dodgeman2289 dodgeman2289 is offline
Vehicle: 97 ram 1500 ss/t 5.9
Trim Level: ss/t
Color: sunset burnt orange
Rep:44
dodgeman2289 is on a distinguished road
i put mine back on.. got more takeoff didnt have to push the throttle as much to get it going. more low end imporved my 0-60 time as well
spectre cold air,sct tuner,ported tb,msdblaster coil,1.7 roller rockers,u/d pulley,180 stat,tranny cooler,transgo tfod-hd2 shift kit,pacesetter headers,cat delete,flowmaster super 10
Old 05-27-2011, 05:11 AM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
Originally Posted by Kilkenny View Post
I can't see how it would work on a 360. That intake manifold is big and the injectors are not even close to the throttle body. The only thing a spacer would do is increase the distance between the throttle body and the inside of the intake manifold. Now the air passes through the filter, through the TB, past the spacer, into the manifold and then gets sucked through the runners from there. Having the spacer there isn't going to change anything. The fuel doesn't come into the equation until after the air is out of the keg.
The only way it would improve power or mpg slightly is if it did something to fool the IAC sensor by somehow making the air in the manifold cooler (I have no idea how it would do this but it would explain the mpg increase that people are reporting). But that can be done for free just by moving the IAC to a different place.
You mean like this...
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
Old 05-27-2011, 05:29 AM
Trim Level: ss/t
Rep:44
Ya i had mine moved when i had my old k&n was great always read under 100 on my air temp
Old 05-27-2011, 05:57 AM
RAMING IT's Avatar
Rep:65
Were abouts the intake was it relocated to? I thing some areas are better than others.
Old 05-27-2011, 03:27 PM
Trim Level: ss/t
Rep:44
mine was in the intake tube on the k&n closer to the tb it worked out great.
Old 05-27-2011, 07:29 PM
TuzaJaime TuzaJaime is offline
Color: gray
TuzaJaime is on a distinguished road
Unhappy I need help with my transmission problem!!
hey guys i need help i have a 2002 dodge ram 1500 pick up engine size 4.7 my gears are going in too fast 2nd gear at 15rmp and 3rd gear at 25 rpm..n when they go in it kinda stalls a bit..i kleaned the throttle body and same thing is there anyway i can speed up the gears maybe on a sensor?????
thanx
Old 05-29-2011, 03:09 AM
Trim Level: ss/t
Rep:44
idk if the 4.7 has a tv cable for adjustment.. my 5.9 when i removed the throttle body and cleaned it while installing my throttle body spacer.. somehow mine got messed up i would go down the road and it would go out of gear or rev up to high and downshift by itself somone told me about tv cable and gave me a link with directions i adjusted mine ever since my truck has been normal.. if the 4.7 has a tv adjustment sounds to me like yours was moved to far forwards causing it to shift early as hell... if its not that if could be something in the tranny.. last time serviced???
