What does your temp gauge read? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Diesel Forums!
Dodge Caliber
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Place your Ad Here!
Old 10-31-2010, 10:43 AM
Dave Meyers Dave Meyers is offline
Vehicle: 2001 Ram
Color: Very red
Dave Meyers is on a distinguished road
Default What does your temp gauge read?
Mine displays about half way between 130 and 210, which seems cool compared to the same gauge on all other Jeeps I own, Grand Cherokee, Cherokee, Liberty, which seem to have same gauge. heat works, not super hot, though. I don't know if there is an issue or not, so I thought I'd find out where your gauages diplay when engine is warmed up. If mine is normal then so be it, otherwise I can check the T Stat.
2001 Ram Quad Cab Sport, 5.9
1973 IHC Scout 33's, lifted, fun
Old 10-31-2010, 10:56 AM
Rep:4264
Although I have a smaller engine than you, as a Jeep owner, I have to agree, my truck runs way cooler, usually around 190-200 when at operating temp whereas my Cherokee (I6), usually ran right around 210.
Old 10-31-2010, 11:04 AM
GPSHSLAX's Avatar
GPSHSLAX GPSHSLAX is offline
Vehicle: 2009 Ram 1500
Trim Level: ST 2X4
Color: Bright Silver Metalic
Rep:236
GPSHSLAX has a spectacular aura aboutGPSHSLAX has a spectacular aura aboutGPSHSLAX has a spectacular aura about
If your gauge is accurate that meant your hanging in the vacinity of 170. If that's the case that's awsome. A bunch of guys here install a 180 t-stat to get those kind of results. Also remember, if you are running the heat, the heater core is like a mini auxilary radiator, only the heat exhausted blows into the cab.
Mods: Thule Xsporter 422XT bed rack, Underrail Rhinolining, MOPAR class IV Hitch, DIY CAI, Aero Turbine 3030.
Future Mods/Wishlist: Tuner, Daystar Comfort Ride 1.5" Leveling kit, Nerf Bars, Police style push bumper with light guards, KC or Thule trail lights, HID projector lights.
Old 10-31-2010, 11:11 AM
Rep:4264
Agreed ^^^^!
Old 10-31-2010, 12:38 PM
Vehicle: 2001 Ram
Color: Very red
I may want to check the T Stat, then. With heater off, it is at about 170, but the heat is not as hot as I am going to want it here in WI in the winter. I am not towing anything, don't need extra cooling, so I'll see what the PO has installed the way of a T Stat. I'd like the truck to run at factory spec temp and produce good heat. Thanks, the feedback was very valuable.
Old 10-31-2010, 02:41 PM
Rep:2929
in the winter, you can always raise the heaters output with the use of some cardboard to block about 1/2 the radiator, if you don't find your answer
Old 11-05-2010, 02:14 PM
Vehicle: 2001 Ram
Color: Very red
I guess I'll swap out whatever T Stat is in there for a new 195 degree. I'll know afterward if the previous owner had a cooler T Stat in there. My thought is that the engine was designed to run at 195, cooler than that will decrease mileage and heater output. I doubt she's going to overheat even in the summer. I've never had a well tuned vehicle do that, old or new. If heat doesn't improve, I'll flush the heater core. After that I'll assume that is the best the heater can do.
Old 11-05-2010, 02:18 PM
Resident Technician
Rep:1915
You should get heater output temps around 140 degrees from the center outlet with the heat on high and operating in recirc mode.
Old 11-05-2010, 02:56 PM
Vehicle: 2001 Ram
Color: Very red
Thank you!
Old 11-08-2010, 09:26 AM
Vehicle: 2001 Ram
Color: Very red
At idle, stuck a thermometer in the vent, reading no where near 140. If I rev engine to 2500 rpm, temp cimbs to 140 then stays there until rpms drop, then temp drops. This is while truck is in park. Temp gauge never changes from about 170. Voltage is always in the "good" zone, never changes. Blower motor speed is constant as well. I am wondering if this indicates clogged heater core. Any thoughts?
