2009 6inch lift questions - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 10-31-2010, 05:14 PM
Slednecks Slednecks is offline
Slednecks is on a distinguished road
Default 2009 6inch lift questions
First of all, hello everyone! I am new to the site.....first thread. I have a 2009 crew cab truck and I just bought a 6 inch lift kit from Rough Country. I am trying to decide what backspacing is needed for the 20" rims so wheels don't stick out too far. I am going with 37" tires also. Does anyone know how this will affect the speedometer and shifting in and out of overdrive on highway?
Old 10-31-2010, 05:48 PM
I see your only running a 4.7 , I'd watch how big you go on tires . If your gonna run the 37's your probably gonna be looking into running a set of 4.56's . As for the wheel backspacing , hopefully someone else can answer that for ya . Don't forget to stop by the newbie section and introduce yourself .
Old 10-31-2010, 06:20 PM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
Welcome to the Z bro.
Ok if you have a 4.7 I would go with 35" tires.I would still regear for 4.56's. If not it wont like OD at all and there goes your mpg.
My speedo is off 5 mph slow in town 0-45 and off 10mph slow on the highwy 70+.
Are you running your stock rims? If your getting new rims I would get a -12 offset. I have -20 offset on my 20x10 with 37's and my tires stick out 4" past the fenders.
If you want to see what my truck looks like here is a thread it is on.My mods are on my sig.
http://www.ramforumz.com/showthread....852#post313852
Old 11-05-2010, 07:14 PM
ScatPak07's Avatar
Rep:970
I would recommend going with an offset of around -10mm to -20mm. I have a -18mm offset on my truck and the tires stick out perfectly. You have to look at the tire width as well. I have a 13.5" wide tire and with fender flares the tires still stick out. The most popular width is 12.5 so anything under -20mm you should be able to cover them up with flares.
I just read you were asking about backspacing. I know some lifts actually specify the max backspacing you can go with. The steering knuckles are smaller then stock so the backspacing needs to be checked. I know my rims have a backspacing of 4.8. Check what your lift kit specifies and go from there.
I have to agree with the other guys and say the 35" tires might work out a little better for you. Thats what I am running and with a 6" lift with 35s are a match made in heaven.
Old 11-05-2010, 08:24 PM
Thanks to all who gave a newbie some help here are my latest purchases. KMC Monster 20x10 with -12 backspacing. Nitto Trail Grappler 35 x 12.5 Lift is being installed and should be done tomarrow. Cant wait to post pics
