Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8 > Exhaust
Exhaust 5.2L Wxhaust Discussion
Old 10-31-2010, 11:24 PM
whosdunit whosdunit is offline
whosdunit is on a distinguished road
Default Oxgn. sensors???
I'm totaly new here, (I dr. a stk 91, D350 168,000mi) to gassers, a friend ask me how to by pass the oxgn., sensors on his 96 1500 5.2(318) 4x4 auto. , I DON'T KNOW but i know where to find out. Sooo, give me the good& bad,and what about the computor? He say;s his has 3, dual exc., & cat. I would think his fuel mpg., would suffer, and run uneven,ya'll tell me i tell him. thanks for the welcome's Tom, and the rest.
Old 11-01-2010, 12:05 AM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
You are absolutely right to be concerned about the computer. O2 sensors analyze the products of combustion and provide feedback to the computer so it can adjust the fuel injectors so the correct fuel/air ratio can be maintained for emmisions control and fuel economy. His 96 most likely has the newer generation On Board Diagnostics(OBDII) computer system. I'm just a shade tree guy, but that is my basic understanding of how this works(experts: feel free to correct me if I am wrong). Probably a bad idea for anyone who has to ask how to do it.
Old 11-18-2010, 03:15 PM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
Cool
There is a way to bypass the 02 sensors its a small module that plugs into the 02 sensor plug and tricking the computer. I just cant recall the name. I'll look for it.
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
Old 11-18-2010, 10:53 PM
jason3506's Avatar
jason3506 jason3506 is offline
Vehicle: 1999 ram 1500
Color: silver
Rep:19
jason3506 is on a distinguished road
wouldnt bypassing the sensors just make the truck run richer? i know more fuel usually means more hp but wouldnt he need to ramp up the air to help burn the extra fuel? just a thought.
Jason
Old 11-19-2010, 11:09 PM
RAMING IT's Avatar
Rep:65
Cool
Computer reads da module as a working sensor thus no reason to burn rich
Old 11-20-2010, 02:49 AM
Rep:3322
The O2 simulators are basically like a resistor in a circuit, so it just presents itself as a functioning sensor, allowing you to remove things like the cats without throwing codes.
Old 11-20-2010, 09:11 AM
Resident Technician
Rep:1915
You don't want to disable the upstream sensors because those are the feedback sensors the PCM uses to calculate the fuel curve. Placing a resistor in the upstream signal will cause the fuel curve to remain basically unchanged which would be bad when the weather changes because it will be running either too rich or too lean. Fuel economy and power would go into the toilet. Then you have to contend with the PCM setting codes because it isn't seen the sensors switching voltages. If he doesn't plan to remove the converters, there's no reason to disable the downstream sensors.
