Old 11-01-2010, 09:07 AM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:71
latitud will become famous soon enough
Default 2010 slt dual exhaust info
I am sure this has been covered separately in different threads, but some info may be missing so here is what I have learned so far:
Stock muffler is 3" in and 2.25" out (duals) (5 1/2" spacing)
26" long body and the rear hangers are welded to the muffler.
Replacement Magnaflow is as follows (5x8 oval):
These are 18" (body) and will require an extension pipe
12278 stainless 3"in/dual 2.25" out
14278 polished
These are 18" (body) but have a 2.5" dual out and will require 2.5" to 2.25" adapter (2 of them) (5x8 oval):
12288 stainless
14288 polished
These are the same as above but 14" body (5x8 oval):
12198 stainless
14221 polished
The spacing of the dual out on the stock muffler is 5 1/2", but you can use any of the ones listed above (most of them have 4" dual out spacing).
There is a 22" (body) polished muffler that is 14588. This one has a 5 3/4" dual out spacing, but the body is 5x11 oval. This one appears to be the most direct replacement, but will require an extension pipe. From what I have read, this will be the most quite replacment due to the length. Apparently the shorter the muffler, the louder it is..this makes sense due to the amount of packing amterial.
Hope this helps.
2010 Dodge Ram, 5.7 Hemi, Crew Cab
Old 11-01-2010, 09:10 AM
Good info! So did you put a system on your truck?
Old 11-01-2010, 09:15 AM
mark09sport mark09sport is offline
Vehicle: 2014 Ram RC SB
Color: Blue streak pearl
Rep:18
mark09sport is on a distinguished road
I hear Mufflex has an exact fit replacment for our dual exhaust muffler in 3 diff. lengths depending on noise level desired.
2014 Ram Express 4x4 Reg cab Short bed 5.7, 8spd, 3.92 gears, Blue streak pearl with all options. 180 T stat, drop in, wrapped intake tube, 24" Mufflex, 2 1/2 lift, Black out ram emblems, Tail light tints.
More MODS to come!
Old 11-01-2010, 10:20 AM
latitud's Avatar
Rep:71
That is correct...I just think they are a little on the expensive side. The magnaflow 12278 is $80 and the extension pipe is $6. I already have duals that will bolt right back up, so $86 vs $240 plus shipping.
This is where is info comes from..I bought 14288 which is 3" in and dual 2.5" out..I didn't want to install adapters, so I am returning 14288 and I bought 12278 instead. Shoudl be here in a couple of days and I will post up some pics and hopefully a video.
Old 01-05-2011, 01:46 PM
djcwardog djcwardog is offline
Trim Level: ST Long Bed, Reg Cab
djcwardog is on a distinguished road
Default Excellent Work!
This is all good info to have as I consider any changes to my stock 2010 Hemi ST single exhaust with resonator. The truck makes the right sounds now but a few more ponies and the look of duals would be nice.
Thanks for your diligence in putting this together for our benefit.
Sincerely, djcwardog
'10 1500 ST Reg Cab Long Bed Hemi 3.55 trac-loc
Old 01-06-2011, 02:29 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Awesome post. You really helped me out on this one, because the 2.5 " outlet was floating around here as well!
Old 01-06-2011, 02:46 PM
916Timmy's Avatar
Rep:1443
Just ordered mine! Do you have any info on the tubing coming out of the cats to the collector pipe? The previous gen rams is 2.5" but not sure on ours. I ordered the 2.5" Y pipe to replace....hope it works!
Old 01-06-2011, 03:03 PM
joey0480 joey0480 is offline
Trim Level: Crew Cab Sport 4x4
Color: Brilliant White
joey0480 is on a distinguished road
I am heading in tomorrow morning to have the y-pipe and magnaflow 14 welded in!
Sylvania 9145ST, H11ST, and 9005ST, Cortex 3950, K&N filter, Magnaflow 12198 and Y-pipe 10778
Old 01-06-2011, 03:05 PM
916Timmy's Avatar
Rep:1443
Talking
I'm all excited! We're making the planet a LOUDER and SWEETER place! One truck at a time
Old 01-06-2011, 03:09 PM
absolutely...I am curious how things turn out because I got the 2.5 muffler and have spoken to some that have had no issues welding that in, so curious if any difference between your 2.25 and my 2.5.
