Rear End - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 11-01-2010, 10:28 PM
Red05Ram Red05Ram is offline
Vehicle: 2005 Dodge Ram 4x4
Color: RED<----
Rep:15
Red05Ram is on a distinguished road
Default Rear End
I want to replace my gears with some 4.10's as soon as I can, but when I do that what else do I have to do to make sure i get posi traction, cuz i kinda took off from the grass the other day and noticed only my right tire spinning real fast, or maybe I am just crazy?!?! lol Any info would help, thanks
K&N FIPK,Diablo Custom tune,TTI Long Tubes,True Dual 2 1/2 inch, Borla XR1 Mufflers,4.56 gears,Jet 180 stat, Fastman TB, Cam Swap
Old 11-01-2010, 10:38 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
I'd suggest 4.10 limited slip. This way when one wheel starts to spin the other kicks in. Good for street driving because one wheel doesn't skip around corners.
Definitely make sure you know what rearend you have so you get gears that fit. You also have to change out both front and rears since you are 4x4.
Brian:
Old 11-02-2010, 02:03 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
Exactly what RB said. Not sure how many miles you have but since you have the pumpkins cracked open you'll want to get "master install kits" to replace all the bearing, races, etc. Being a 4x4 you'll spend $1300+ and that's if you don't go to the dealership.
4.10s sure would wake up your performance! If you are running a 35-37" tire I'd recommend some 4.56s
Old 11-02-2010, 02:54 AM
Color: RED<----
Rep:15
Ya i eventually will be but i dont want my 3rd gear to top out at 105 ya know? Thats one of the main reasons im going 4.10, i had a 2001 with 4.10's and I had no complaints, and with this truck having like a hundred more horses im excited to see what it can do! Also you were talking about master install kits, where can i get those?
Old 11-02-2010, 10:17 AM
CHVYKLR's Avatar
Rep:252
Here is a master install kit. They aren't for the right axle but just an example.
http://nationaldrivetrain.com/shopsi...kits_diff.html
Here is a page where you can calc your RPM.
http://www.ringpinion.com/Calc_RPM.aspx
Old 11-03-2010, 05:50 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
http://moesperformance.com/index.php...th=1_1200_1203
Has both front and rear MIK's
Old 11-04-2010, 11:43 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
i said 4.56 a lot of members i seen ha 4.10 like them but wanted 4.56 that just my 2 cents that what i going to do
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 11-05-2010, 07:29 PM
ScatPak07's Avatar
Rep:970
I see you have the sport model truck so going to 4.10s would be a waste of money. You should have the 3.92 gears like I do since I have a sport as well. Going from 3.92 to 4.10 is such a small change you wont even notice. Go with the 4.56 gears and a LS.
Whatever gears you put in the rear you should do to the front as well. You have a 4x4 so if you leave the front stock you will never be able to use the 4x4 unless you want to break things haha.
Old 11-06-2010, 11:57 AM
What gear ratio do you have now ? There should be a tag on the rear cover . Remember if you have 4x4 you will need to do the front diff also .
