New Guy with two (HOPEFULLY) simple problems... - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 11-01-2010, 10:32 PM
All Thumbs's Avatar
All Thumbs All Thumbs is offline
Vehicle: 1997 Dodge Ram 1500 Ext cab
All Thumbs is on a distinguished road
Default New Guy with two (HOPEFULLY) simple problems...
1. When I put it in gear, it starts moving slowly for just a few seconds. It makes a sound that's not quite a whining sound (like a belt or pulley) but more like it's 'complaining' (I can't think of how else to describe it). It only lasts for a few seconds, but I know that it can't be a good sign.
2. I can hear 'water' running from what sounds like the passenger side firewall. I removed the cowling at the bottom of the winshield and checked the drain holes but they were clear.
Ideas...?
Please keep in mind that I am a rookie shade-tree mechanic...
Old 11-02-2010, 03:03 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Sounds like air in the heater core. Does your heater work properly?
This is rather common after cooling system has been drained and re-filled (air lock), and also is common near the failure time of the heater core. Do you smell antifreeze in the cab? or see any drops on the passenger side floor?
brad
Interested in one of my mods?
Old 11-02-2010, 02:28 PM
moparmud89 moparmud89 is offline
Vehicle: 1994 ram 4x4, 1974 power wagon
Trim Level: laramie slt
Color: red 94 green 74
moparmud89 is on a distinguished road
As for the whining does it only do it while in gear? say it whines in Drive and Reverse but immediately stops when placed in Park? if so i'd say probably torque converter is likely. It may drive ok but make the noise, if so quit driving it and replace the torque converter so you can save the tranny (did mine recently, TC=$600, GOOD rebuilt Tranny $2000). as for the water noise, pull up the carpet on your passenger side and check for a small amount of water or rust showing that water has been there. if so get either a pipe cleaner or compressed air and clean out the vent tube sticking out of the fire wall below your accumulator, it will clog and drain a small amount of water in the cab. Mine made noise like that but usually only when the AC was on
Old 11-02-2010, 11:04 PM
Dennyboy's Avatar
Dennyboy Dennyboy is offline
Vehicle: 1999 regular short box sport
Rep:140
Dennyboy will become famous soon enoughDennyboy will become famous soon enough
Im guessing what he said. But how do you go about fixing that i haven't the slightest idea.
Dakota County Technical college
Auto Tech apprentice
cataclysmic perverter
If you don't stand behind our troops, PLEASE feel free to stand in front of them.
Old 11-02-2010, 11:40 PM
All Thumbs's Avatar
Thanks bros. I was hoping to avoid screrwing with the heater core, but that looks like the best answer since I've checked all of the drains. That and a Torque Converter change should keep me busy for the next month or two...
Old 11-03-2010, 12:05 AM
Fatmandue's Avatar
Fatmandue Fatmandue is offline
Vehicle: 2012 Dodge Ram 4x4
Fatmandue is on a distinguished road
good luck to u.
Rep:2954
the gurgling sound could very well be air in the heater system, if air is in there, it could be in the radiator system too
maybe it needs to be burped
Old 11-03-2010, 12:38 AM
cannotdodgethedart's Avatar
cannotdodgethedart cannotdodgethedart is offline
Vehicle: 1998 Dodge Ram SS/T
Trim Level: Super Sport Truck
cannotdodgethedart is on a distinguished road
Make sure you purge the air out of the system and check the levels
Old 11-03-2010, 11:50 PM
All Thumbs's Avatar
OK...How the *blank* do I get the air out of the system? Can I just fill it and let it circulate...?
Old 11-03-2010, 11:57 PM
Rep:4328
Best way I found to get the air out of the cooling system, and, mind you, I'm no mechanic, just a little DIY on my own vehicles, pop the radiator cap off and start your truck. As it warms up, you'll see the coolant bubble and the level probably drop a bit. Add coolant as needed and you can also work the upper radiator hose, that helps to get air out as well. Let it run until it's no longer bubbling and the coolant level stays where it should. I would also recommend having someone keep an eye on your temp while you're doing this, but like I said, this worked for me, and as with anything, it's best to consult with someone qualified before performing any procedure, but good luck and let us know how you make out.
