Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Dodge Ram Decals
Old 11-01-2010, 10:51 PM
ChrisSylvester ChrisSylvester is offline
ChrisSylvester is on a distinguished road
Default Engine swap question
I am about to do an engine swap on my 96 Ram 1500 4x4 with a 5 speed....It has the 5.2 magnum motor.....I am wanting to put in the magnum 5.9 motor (GAS) in....the only difference is that the motor came from a 97 Ram with the auto tranny.....What will I need to switch out besides the computer.....like clutch, flywheel, flex plate...is it all interchangeable????
Old 11-01-2010, 10:52 PM
cannotdodgethedart's Avatar
cannotdodgethedart cannotdodgethedart is offline
Vehicle: 1998 Dodge Ram SS/T
Trim Level: Super Sport Truck
cannotdodgethedart is on a distinguished road
Yes all of it should be interchangable
Old 11-01-2010, 10:58 PM
Make sure the back of the crankshaft will accept a pilot bearing . The 5.9 is externally balanced so you will need a flywheel for a 5.9 . The computer will work . It will need the flash for a 5.9 . From what I can find everything else looks the same . If it were me I would install the bigger diameter clutch (12") thats available .
