Old 11-02-2010, 09:49 PM
argo argo is offline
Vehicle: 1998 dodge 1500
Trim Level: larame
argo is on a distinguished road
Default radiator
i just replaced the radiator and thermostat in my 98 ram 1500. my quandry is, after refilling the system and running for at least 45 minutes, my lower radiator hose is still cold and the radiator does not build pressure. it acts as if i have an air lock. the thermostat is opening and closing as it should. is this possible
Old 11-03-2010, 12:02 AM
Dennyboy's Avatar
Dennyboy Dennyboy is offline
Vehicle: 1999 regular short box sport
Rep:140
Dennyboy will become famous soon enoughDennyboy will become famous soon enough
Is there fluid flowing? What brand stat did you use? Is you temp gauge reading anything?
Dakota County Technical college
Auto Tech apprentice
cataclysmic perverter
If you don't stand behind our troops, PLEASE feel free to stand in front of them.
Old 11-03-2010, 05:33 AM
Trim Level: larame
the stat is from napa............ the temp gage is reading normally,reaches 190 stat opens temp drops to about 160. it seems that when the stat opens the lower hose heats up, when it closes the hose cools down.
Old 11-03-2010, 06:58 AM
You did install the thermostat correctly ? The bulb in towards the motor .
Old 11-03-2010, 09:09 AM
Rep:1877
It's possible you could have air in the system. Are you positive that you have flow from the water pump and that the thermostat isn't in backward?
Old 11-03-2010, 05:15 PM
Trim Level: larame
yes the bulb towards the motor
Old 11-03-2010, 05:17 PM
Trim Level: larame
thermostat is in correctly
Old 11-04-2010, 11:46 PM
Dennyboy's Avatar
Rep:140
shouldn't be going down to 160 sounds like you have air in the system. let it run with the cap off and squeeze the hoses slowly and add coolant while doing it. \
Also how much coolant did you add? Did you take the water pump off at all?
