Old 11-07-2010, 07:30 PM
ramajama10's Avatar
ramajama10 ramajama10 is offline
Vehicle: 2010 dodge ram 1500
Trim Level: sl
Color: metalic black!
ramajama10 is on a distinguished road
Default tailgate firestrip issues
i just got the fire strip led light bar for my 2010 dodge ram. when i have the lights off and use my turn signal or brakes it works fine. but when i have my headlights on ofcourse the led's light up on the strip but the turnsignals on the strip dont blink. they just stay the same way they were. has anyone else had this issue or know what the problem may be. also on the little box that all the wires run from theres a very short wire that just hangs there with a plastic piece on the end of it. anybody know what thats for. all comments are greatly appreciated. thanks
If you can't stand behind our troops, stand in front of them.
Old 11-07-2010, 07:49 PM
Chili1K's Avatar
Chili1K Chili1K is offline
Trim Level: TRX4
Color: Email: Chili1k@att.net
Rep:1092
My guess would be you have the wrong wire hooked up to the running lights or there is a crossed wire somewhere in the harness..
check the harness and if you put power to the other hanging wire what happens?
GL..
Old 11-07-2010, 09:20 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
yea id would think the same thing you must have the wrong wires hooked up just fiddle around with it and see if it will work
Old 11-07-2010, 09:41 PM
moparornocar72's Avatar
Rep:630
hanging wire must be for reverse as mine on my rampage was seperate from the main wiring because u have to tap it into the tailights reverse. as for the other problem, it sound like u have the wires crossed or something didnt get wired in right. double check the wiring and put power to the other wire hanging loose and see if you don't get a reverse. check ur connection. hope this helps!
14.268 @ 95 MPH Full Trim
Old 11-07-2010, 09:57 PM
ramajama10's Avatar
Trim Level: sl
thanks for the coments. i used a 4 pin conector that came with the light bar. u cant take it off tho. its perminatly connected to the harness for the light strip. the other round connector is right under the 4 pin. is there a adapter for that or something? i dont really think i could have crossed wires cause it only goes in one way.
Old 11-09-2010, 12:32 AM
ramajama10's Avatar
Trim Level: sl
still no luck. and still not sure what the extra wires are for. i put power to them and nothing. when my headlights are off the strip works fine but as soon as i turn them on the strip just stays lite up. no turn signal, or brake lights. i dont understand this. any more suggestions?
Old 11-14-2010, 12:45 PM
HEMI5150's Avatar
HEMI5150 HEMI5150 is offline
Vehicle: 2010 Dodge Ram Quad 4X4
Trim Level: SPORT
Color: Black Pearl
Rep:35
HEMI5150 is on a distinguished road
Sounds like you might have a bad unit if you know your wiring job is correct
(probably a bad diode in the unit causing power to flow wrong direction)
Not the first time i`ve seen this happen with aftermarket LED lighting
....cheap cheezy chineze made shit
You might be able to bullshit your way to the top, BUT, it wont keep you there
Never believe what you hear, and only half of what you see
Old 11-14-2010, 11:22 PM
Rep:630
yeah agreed the light bar might be bad!
Old 11-16-2010, 01:31 AM
ramajama10's Avatar
Trim Level: sl
true... made in china = POS. i guess i got what i paid for. still makes no sense. so if i use a trailer hook up in that same input i wonder if the trailer lights will do the same thing. if so waranty should cover it rite???
