heating problem - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 11-04-2010, 09:54 AM
atb1137 atb1137 is offline
Vehicle: 2003 dodge ram 1500
atb1137 is on a distinguished road
Send a message via AIM to atb1137
Thumbs down heating problem
my 03 isnt getting any heat. i searchd the forum and looks like a problem for a lot of people but i didnt really find an answer. everytime i turn my heat on it just blows cool air and when u first turn it on you can smell antifreeze. even when the truck is warmd up it still pushes cool air out. any help is greatly appreciated.
Old 11-04-2010, 10:10 AM
Resident Technician
Rep:1915
If you smell coolant, you have a bad heater core for starters. Chances are its blocked so when you replace it, you should flush the cooling system as well.
Old 11-04-2010, 10:19 AM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:78
latitud will become famous soon enough
Blend doors were borken on mine and I had to tear the dash out to replace all three doors...but I didn't ever smell antifreeze..so I am also leaning toward heater core..which requires the same tear down of the dash I believe. So if it is the core, check the doors while the unit is apart.
2010 Dodge Ram, 5.7 Hemi, Crew Cab
Old 11-05-2010, 12:36 AM
okkk last winter i noticed it was semi hot air n now its just completely cold..thanks for the help fellas
Old 11-06-2010, 08:16 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
Yep sounds like heater core is blocked and sprung a leak.
Sure it'll suck, but it'll make you a man
Old 11-06-2010, 09:30 PM
With the engine at normal operating temp , check the temp of your heater hoses by hand . If it's plugged up you should feel alot of temperture difference between them .
Old 01-23-2011, 06:55 PM
bigmike19956's Avatar
bigmike19956 bigmike19956 is offline
Vehicle: 2002 Dodge Ram 1500
bigmike19956 is on a distinguished road
I recently had a similar issue. Trust me, it is not fun driving to work in 20 degree weather with NO heat. I pulled the glove box down and the door located at the back would not move. I pulled the heater motor out and reached up there to move it. It fell off in my hand. The good part is that I now have full on heat. I do not plan on replacing the door until if I see it affects my a/c come summer time. I know this is not a proper fix, BUT it is working for me.
Old 01-23-2011, 06:59 PM
Resident Technician
Rep:1915
You should at least block off the recirc opening so the air is only coming from the outside. This will help prevent window fogging.
Old 01-24-2011, 02:52 AM
letzroll letzroll is offline
letzroll is on a distinguished road
My 2002 ram 4x4, 4.7 L has a weird problem, the passengers side heat outlets are really hot, upper and lower and the drivers side are way cooler ,feet get cold on drivers side only could this be a stuck door somewhere ? seems like cold air is mixing with the drivers side only ,anyone had this problem?also I noticed there are extra heater hose connection tubes on the firewall below the regular heater hose connections,they look open ,could cold air come in there maybe? Thanks
Old 01-24-2011, 03:21 PM
Red Ram Girl's Avatar
Red Ram Girl Red Ram Girl is offline
Vehicle: 2004 Dodge Ram Quad 4x4
Color: Red/Black interior
Rep:13
Red Ram Girl is on a distinguished road
Exclamation Heat doesn't go to floor or defroster, only vents...?
I have a 2004 Hemi 5.7 4x4 Ram.
Just recently we had quite a cold snap, much below zero. Now the heater will not go to the floor or the defroster, just blasts through the center vents.
Tough to drive because the windshield is frozen. On the floor it's cold toes. Then an overheated middle section. I live in Minnesota.
I've heard that Dodge knows of this problem (Blend Doors breaking or locking) but will not put out a recall for it. SHAME on you.
What should I do RAM PEOPLE?????????????
