Old 11-04-2010, 02:13 PM
srtsir's Avatar
srtsir srtsir is offline
Vehicle: 2004 Dodge Ram
Rep:198
srtsir has a spectacular aura aboutsrtsir has a spectacular aura about
Default Found a cam installer...
Ok guys I was searching for a cam installer here locally and i finally found one to do it..He is going to charge me 500 dollars for install only I have to get parts...Is this a good deal??
Also can anyone give me a parts list of all the things I need..I will be buying a cam from interia motorsports...I was thinking about getting a Crazy Jay..How does this cam perform??
5.7 HEMI, DIABLO, K&N INTAKE, MBRP CATBACK, 4.56 MOTIVE, DMH E-CUTOUTS, 22X10 SRT-10 RIMS (BLACK), 315/45/22 COOPER ZEON XST'S, 2/4.5 MCGAUGHYS DROP KIT, 6K HID'S FOGS & HEADS, RECON L.E.D TAILGATE STRIP, EFX ROLLPAN, TRUXEDO LO-PRO, HORNBLASTERS 156DB TRAIN HORN, HONEYCOMB GRILLE....
Old 11-04-2010, 02:17 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
there a guy her doing it for me once i get this god damn tuner his name willbreakloose. he a great guy. 500 is fine. you need spring valve retain crank bolt. call and ask for art at Henson motor sport for the basic cam parts.
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 11-04-2010, 06:29 PM
srtsir's Avatar
Rep:198
I am looking for a good low to mid range tq cam....Something to get me better 1/4 mile...My truck is QC 2wd with 4.56 gears what do you guys recommend for a cam in my truck?? I heard KRC 210 is good but thats more for 4x4 trucks right..What would a good cam be thats easily tuned with my diablo??
Old 11-04-2010, 11:40 PM
Trim Level: st
Color: silver
Rep:68
i got the 210x the 210 is different do you want mds friends or what? there also crazy jay for interia there a cupple out there
Old 11-05-2010, 02:19 AM
srtsir's Avatar
Rep:198
I dont have MDS in my truck its a 04...
Old 11-07-2010, 05:21 PM
Trim Level: st
Color: silver
Rep:68
o ya forgot. yes this guy doing mine did alot cams swaps
Old 11-07-2010, 07:51 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
I wouldn't buy a low end cam if you are running 4.56 gears. Those gears give you all the low end you need. A mid to high end cam and a new stall (something like 3k rpm) is what I'd shop for...just my opinion.
Old 11-07-2010, 11:22 PM
Trim Level: st
Color: silver
Rep:68
krc210x with 4.56 really um ok
Old 11-07-2010, 11:26 PM
Trim Level: st
Color: silver
Rep:68
let me show you the new ones
210/214 523/526 108+4
here some info about cams also
Thought i would just post up the info
Tighten (smaller LSA number)
Moves Torque to Lower RPM
Increases Maximum Torque
Narrow Power band
Builds Higher Cylinder Pressure
Increase Chance of Engine Knock
Increase Cranking Compression
Increase Effective Compression
Idle Vacuum is Reduced
Idle Quality Suffers
Open Valve-Overlap Increases
Closed Valve-Overlap Increases
Natural EGR Effect Increases
Decreases Piston-to-Valve Clearance
Widen (larger LSA number)
Raise Torque to Higher RPM
Reduces Maximum Torque
Broadens Power Band
Reduce Maximum Cylinder Pressure
Decrease Chance of Engine Knock
Decrease Cranking Compression
Decrease Effective Compression
Idle Vacuum is Increased
Idle Quality Improves
Open Valve-Overlap Decreases
Closed Valve-Overlap Decreases
Natural EGR Effect is Reduced
Increases Piston-to-Valve Clearance
Advancing
Begins Intake Event Sooner
Open Intake Valve Sooner
Builds More Low-End Torque
Decrease Piston-Intake Valve Clearance
Increase Piston-Exhaust Valve Clearance
Retarding
Delays Intake Closing Event
Keeps Intake Valve Open Later
Builds More High-RPM Power
Increase Piston-Intake Valve Clearance
Decrease Piston-Exhaust Valve Clearance
Old 11-10-2010, 07:45 PM
wilbrakloose's Avatar
wilbrakloose wilbrakloose is offline
Rep:26
wilbrakloose is on a distinguished road
if you're buying from Inertia you should call them (Stu) and get they're advice, they have been doing this for a wile they know what works if not the Comp 268 it's a great performance cam an will fit perfect in your setup
nothing i can think of
