Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 4.7L (287 cu in) PowerTech V8 Specific Topics
Old 03-27-2011, 12:11 AM
canoeman16 canoeman16 is offline
Vehicle: 2002 Dodge Ram 1500 SLT 4x4
Rep:12
canoeman16 is on a distinguished road
Default Sludge and rough idle update
Just a note to update the group on my sludgy engine that is running very rough. No problem with the ignition side, but after doing a compression check, I discovered that cylinders 2 thru' 8 had a compression of 130 to 145 psi. Number 1 had a rating so low it would not move the needle. I pulled the valve cover off and jogged the engine - all the valves appeared to be moving up and down in a normal fashion. So, I suspect my next step will be to pull the head. Now I need to get the special service tools that the manual says I need. Any suggestions or words of advice
Old 04-12-2011, 06:46 PM
ramoreno's Avatar
ramoreno ramoreno is offline
ramoreno is on a distinguished road
Post
IMO change your oil is the best you can do, im using a oil catch can too. And using Chevron supreme 10w-40 with bosch filter. and that works for me. oh, and put your foot into the gas pedal some times to to rev the machine.
Again Sorry for my english
Old 04-18-2011, 01:43 AM
Rep:12
Well, it looks like I have discovered why my 4.7 is sluggish, has a rough idle and no power. Please take a look at these photos and give me some advice on why this happened. I intend to replace rather than repair this engine. I just don't want to repeat it a second time. Anyone know where I can get a decent engine at a decent price in Canada - specifically Winnipeg, Manitoba?
Maybe I can replace it with a Hemi - anyone got advice on that road?
Old 04-18-2011, 01:55 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
detonation from all the carbon build up
Old 04-19-2011, 12:50 AM
Zippo973 Zippo973 is offline
Vehicle: 2011 Dodge Ram
Color: Black Pearl
Rep:42
Zippo973 is on a distinguished road
what kinda fuel you Knucks use up there eay?
Old 04-19-2011, 10:06 AM
charlieb's Avatar
charlieb charlieb is offline
Vehicle: 2004 dodge ram 1500
Rep:31
charlieb is on a distinguished road
wow nice pics i could see that hole causing some power loss, lol.well doesnt seem like an oil issue seems like a pre ignition problem can cause the build up and damage around plug holes and possibly the hole in ur piston.
Old 04-19-2011, 10:22 AM
Rep:1885
I see evidence of water intrusion in the #1 cylinder. The carbon buildup isn't likely to be from a rich fuel mixture unless you have defective upstream O2 sensors. The PCM is programmed to shoot for a 14.7:1 stoicometric air/fuel ratio. Can't say I've ever seen a pedestal come off a tensioner like that before.
Old 04-19-2011, 07:13 PM
FDBDW's Avatar
FDBDW FDBDW is offline
Vehicle: 2009 Dodge Ram
Trim Level: Big Horn, 5.7 hemi
Color: BRILLANT BLACK CREW CAB
Rep:172
FDBDW has a spectacular aura aboutFDBDW has a spectacular aura about
Man that hurts , Rep points for posting some very educational pics. Not that its gonna ease the pain but thanks for sharing.
MOPAR CAI , 14" MUFFLEX, Diablo Intune 91oct , 2.5" LEVEL, K2 OPEN BLACK MESH GRILLE, FRONT WINDOWS TINTED, ROCKSTARS ON 295/70/18 NITTO TRAIL GRAPPLERS, LARADO BED COVER, DEBADGED, GO RIHNO STEPS , RECON SMOKED TAIL & THIRD BRAKE LIGHTS , PAINTED HEADLIGHTS , SPEEDLOGIX CATCH CAN, FASTMAN PORTED TB ,
Old 04-20-2011, 01:07 AM
Rep:12
It's Canada - so it's 1/2 gas - 1/2 antifreeze. lol I have used 100% synthetic oil and regular gas since I got the truck.
