Old 11-07-2010, 04:17 PM
JakeRam02 JakeRam02 is offline
Vehicle: 2002 Dodge Ram
Trim Level: 1500 Sport
Color: Graphite Metallic
JakeRam02 is on a distinguished road
Default Grille Insert Removal
searched the site and couldn't find a thread with instructions on how to remove the grille inserts on an 02-05 Ram. i gave it a shot but i can't get it out without damaging the stupid plastic rivet things. any help is greatly appreciated.
Old 11-07-2010, 06:31 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
im not sure how it is on the older models but on my 09 i had to take the bolts out on top of the grill and then there were clips and i just pulled straight out
Old 11-07-2010, 06:33 PM
The rivets have to be drilled out.
Old 11-08-2010, 12:59 AM
thomasspink's Avatar
thomasspink thomasspink is offline
Vehicle: 2004 Dodge Ram 1500 SLT 4x4
Color: Grey
Rep:76
thomasspink will become famous soon enough
you dont have to 'drill' them out if you find something small enough that can go in the center hole, like a nail, is what i used you can pop them right off, just give it a little tap and BAM there off!!! i just used zip ties to replace them with!
Old 11-08-2010, 08:37 AM
I will be using the small screws that go back into the holes there. I just will make sure I use the right sized drill bit.
Old 11-08-2010, 09:48 AM
Color: Grey
Rep:76
just be carefull that you dont drill out too much stuff i have seen that
grille, insert, removal
