Old 11-07-2010, 10:50 PM
MOPAR MULiSHA's Avatar
MOPAR MULiSHA MOPAR MULiSHA is offline
Vehicle: 2012 Dodge Ram 1500
Color: Sage Brush Pearlcoat
Rep:219
MOPAR MULiSHA has a spectacular aura aboutMOPAR MULiSHA has a spectacular aura aboutMOPAR MULiSHA has a spectacular aura about
Default Couple Rough Country 4" Lift Questions
I have a 07 Ram with 295/70/17's on stock 17's and I've been eyeing the 4" Lift they have and was wondering if anyone else has it? In my Search I found everyone that has a RC lift has the 6" except I believe Ruffian has the 5" but I was looking at the Bilstein 5100's to level it for now (front and rear) would I be able to use these still and stash the RC shocks/struts in the closet? As for the wheels would I need spacers? They are the perfect size and don't plan on getting rid of em anytime soon.
2012 Sage Brush Pearlcoat Ram 1500 Big Horn Crew Cab Hemi 4x4 w/ Ram Box Storage System
Old 11-07-2010, 10:53 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
To be honest, because of the price difference I would go with the 6" lift because it's about the same price as the 4". I'm can't answer your question though, just wait and someone who knows what they are talking about will get to you.
Dillon-aka, The Little Kid
Old 11-07-2010, 10:55 PM
Rep:1625
You're right, but his tires might look too small with a 6" lift.
Old 11-07-2010, 10:59 PM
Rep:219
Red face
Exactly why I want the 4" like I said the size tires I have are perfect but want a little more lift without making em look like midget wheels lol. But I did see that there was only a slight price difference between the 4" & 6"
Old 11-08-2010, 08:17 PM
ScatPak07's Avatar
Rep:970
I have to agree and say spend the extra $200 and get yourself the 6" lift. I almost bought myself the 4" lift but then I realized I will regret not doing the 6" for only a couple hundred more.
The good thing is you have 17" rims which would make your tires cheaper to buy. If you had 20s like me it would cost a crap load for tires. It wouldn't be that bad if you had to change the tire size to accomodate the bigger lift.
Old 11-08-2010, 10:14 PM
Ruffian11's Avatar
Ruffian11 Ruffian11 is offline
Rep:140
Ruffian11 will become famous soon enoughRuffian11 will become famous soon enough
I have the 5" only because that was the biggest i could get from them for my truck...havent looked into the 06-08 lifts but if they offer a 6" lift i would jump on that being the price is not much different
You will be happier in the end doing the 6" as the 4" still makes the 1 ton trucks around the same height and we all want to be the tallest on the road! Also if you ever decide you want bigger tires you can fit em on the 6"
2005 SLT 1500 5.7L Hemi
5" Rough Country Lift, Procomp 8101 20x9 Rims, K&N CAI,Flowmaster Exhaust Cat-Back Dual Exit, 325/60/20 BFG KM2, Tonneau Cover, Bedlined, Grill Hella 500's!
Alpine CDA-9887 Headunit, Twister 300 Amp, Dual 10" MTX Thunders, Thunder Form Box
Old 11-08-2010, 11:26 PM
SUL7ENAZ's Avatar
SUL7ENAZ SUL7ENAZ is offline
Vehicle: 1999 Dodge Ram 1500 QuadCab
Color: blue
Rep:463
SUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of light
DO the 6" Lift. You are already planning on going higher and it is addicting! I started with a 3" pro comp spacer lift, graduated to a 7" skyjacker and after all was said and done ended up with a 12"-14" custom lift. Get the bilsteins. wear out your tires add the 6" RC lift and new wheels and you'll be able to clear 37's!
SUL73NAZ
Old 11-09-2010, 05:59 AM
Rep:219
Lol sounds like I might be going 6! won't I need a spacer for a 35x12 1/2 on a 17x9 wheel?
Old 11-09-2010, 01:01 PM
SUL7ENAZ's Avatar
Color: blue
Rep:463
Correct. Spacer or bilstein 5100's. I'd go with the bilsteins.
SUL73NAZ
Old 11-09-2010, 01:47 PM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
Just get a 6" BDS Lift with the 5" rear kit and get a 1" spacer for the front.It will clear 37x13.50 easy.Trust me I have 37x12.50x20 with a 20x10 -20 offset rim.I can put 37x13.50x20 tires on there and they will clear easy.I will be doing the 13.50's when I need new tires.I can get you the lift pretty cheap.
