? On lifting my 2WD - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 11-08-2010, 02:45 AM
zwilso56 zwilso56 is offline
Vehicle: 2000 Dodge Ram 1500
zwilso56 is on a distinguished road
Default ? On lifting my 2WD
If I put a 2" on the front I'll be okay to run 33's right?
Old 11-08-2010, 07:17 AM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
It might rub some.Are you putting the tires on your stock rims?
Old 11-08-2010, 08:19 PM
ScatPak07's Avatar
Rep:970
since you have a 2wd truck the tires might rub wth stock rims. 4x4 trucks naturally sit a couple inches higher and with a level the 33s fit perfect.
Old 11-10-2010, 11:09 PM
mholla00's Avatar
mholla00 mholla00 is offline
Vehicle: 08 Ram 1500 custom
Rep:45
mholla00 is on a distinguished road
It all really depends on the offset of your wheel. I run 33's on my 2wd with XD Addict rims with no rubbing, I even ran 35's with minor rubbing at a full turn when I hit a bump. This is all at stock height. I am putting on a 2-3" coil spacer on friday and when we did some very intense measuring we came to the conclusion that my 37's will fit with minor rubbing. God bless the wide fender wells of a dodge
Old 11-11-2010, 03:35 PM
Rep:463
Yeah the wide fenders are really nice.I have an 8" lift and I have 37x12.50x20 Nitto Trail Grapplers 20x10 Moto Metal with -20 offset.My tires stick out 4' past the fenders.
Old 11-12-2010, 06:09 AM
Ostranza's Avatar
Ostranza Ostranza is offline
Vehicle: 2005 Dodge Ram 3500 QuadCab
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft
Rep:68
Ostranza will become famous soon enough
Your tires stick out 4feet from the fenders?! Jesus I guess thats what they mean by long travel A-arms!
Old 11-12-2010, 03:56 PM
Rep:463
Ya they stick out 4 feet.Geez.
Old 04-17-2012, 01:43 PM
UB40 UB40 is offline
Vehicle: 2008 Dodge Ram 4 door 2whl dr
Color: pewter
UB40 is on a distinguished road
I have a 2008 2wd with the 2 1/2 in spacers with 295/60/20 which comes out to be a 34.4 in tire it does fit but it does rub at full turn even with 1/4 spacers behind rim its not to bad but the issue I found is finding a shock to fit after you lift the truck Ive spoken to reps at Rancho and they dont know of one that will meet my needs I currently have Moroe cyntrac.
Old 04-17-2012, 03:30 PM
Hemi1536's Avatar
Hemi1536 Hemi1536 is offline
Vehicle: 2011 Ram 1500 ST
Trim Level: ST Quad Cab
Rep:13
Hemi1536 is on a distinguished road
why would you lift a 2wd? sorry but just makes no sense to me
Never Butt Heads With A Ram
Old 04-18-2012, 12:03 PM
bigreid's Avatar
bigreid bigreid is offline
Vehicle: 2011 Ram
Rep:23
bigreid is on a distinguished road
Ok this one jumped out at me. I have a 2011 express 2wd and about to get a 7" cst lift. The better question is why would you dump a ton of cash into a vehicle and tear it up? A clean lookin' jacked up truck is the best lookin thing on the road.
Also 4th gen rams come stock with 33's. With a 2.5 level you can fit 35's. Tried it, doesn't rub at all at a full left and right cut.
Project Diamondback
