Old 11-08-2010, 02:15 PM
jordanj273's Avatar
jordanj273 jordanj273 is offline
Vehicle: 2003 dodge ram 2500
Trim Level: SLT Sport
Color: silver
jordanj273 is on a distinguished road
Default less MPG?
so i bought my 03 2500 about a month ago and the guy i bought it from said he just did the oil and any other basic maintenance. i checked the oil before i left his just to see for myself. since then i have driven it a little over 3000 miles and is time for a oil change. i took it to jiffy lube changed the oil and changed power steering fluids. I have driven it 60 miles since and have been getting less mpg... i know its a truck and is not suppose to get good mpg but it is getting 10 instead of the 12 to 13 i was getting before. am i missing something here?
ps yes i got my oil changed at jiffy lube due to lack of tools and they had a special for 15 bucks.
Old 11-08-2010, 02:37 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Not sure this would affect mpg because your truck does not have MDS, but what kind of oil did they put in it? What else did they do (change tire pressures, air filter, etc etc)?
Brian:
Old 11-08-2010, 04:04 PM
Kleeeen
Very interesting keep us informed
Old 11-09-2010, 09:53 AM
jordanj273's Avatar
Color: silver
i know that jiffy does check the tire pressure so that could be something to check out. as far as oil goes i put high mileage 30/10 pennzoil and yes i did replace the airfilter.
Old 11-09-2010, 08:34 PM
js1977's Avatar
js1977 js1977 is offline
Vehicle: 2011 Dodge Ram
Rep:124
js1977 will become famous soon enoughjs1977 will become famous soon enough
Keep in mind, if your driving into the wind, you'll get less MPG on a windy day, I found that out this weekend when I drove to Texas from Missouri. I got 13 to 14 going to TX but got 16 to 17 coming back. I won't mention my speed but lets just say it was ticket worthy, lol.
What do I know, I'm just some dumb peckerwood that lives in the country with too many guns...
Old 11-09-2010, 09:52 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
do you know what oil the old owner was using and do you know what grade of oil Jiffy used?
Old 11-12-2010, 02:31 PM
jordanj273's Avatar
Color: silver
i do drive in the wind allot but its nothing new to me so it shouldnt change that much.
fred: yea the previous owner went to jiffy too so they had all his records. when i went in i used the exact oil the previous owner used.
as for the status i havent been able to check stuff out in detail cause Ive been working allot (12 hour days 6 days a week)
Old 11-15-2010, 09:52 PM
ScatPak07's Avatar
Rep:970
If the truck is starting to get worse mileage then you should maybe look into cleaning out the induction system. I did that to my truck and they clean out the throttle body and a bunch of other motor parts. I forget now what they all were. if you go to your closest dealer they may have that there for you to do. I noticed a big difference in responsiveness and a bit better MPGs. I only had 60,000kms on the truck when I did it but that shows how often you should clean out the trucks breathing system.
I dont know but it might be the fact that the truck is being given $15 special oil changes as well haha. You might start getting sludge buildup in the motor which might cause the truck to run like a dog. If you want the truck to run perfectly and to last long you might want to spend a little more when it is time for an oil change. Putting in a good oil makes a big difference in the trucks wear and tear of the motor. Spending an extra $50 every 5,000kms (3,000m) makes a big difference. And if you switch over to synthetic you can actually go longer without an oil change which in turn breaks even with the cost since you need less oil changes. I thought I would put my $.02 in, try to help you out for the future
Old 11-15-2010, 10:03 PM
chefred112's Avatar
Rep:656
...have you changed the plugs since you got it? also, consider going to full synthetics as well..
Old 11-15-2010, 10:45 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
if it was me i and i might be wrong i would try this. Like people said check the filter, plugs tires, make sure you got all good air pressure, check see tires or old, check the fuel injectors (It might fix it). This might fix it but will cost you a bit. Try a new intake and a superchip and try a different grade fuel. go change your oil your self (you can use what oil you want compared to what they use)
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
