Old 11-08-2010, 04:46 PM
Shreve T's Avatar
Shreve T Shreve T is offline
Vehicle: 2013 black Gold
Trim Level: Larime Longhorn
Rep:27
Shreve T is on a distinguished road
Default Filler Neck Bulletin
Someone here had a copy posted of the Gas Filler Neck poping out when re-fueling can you re-post it please ??
Old 11-08-2010, 05:29 PM
Jim Ram's Avatar
Jim Ram Jim Ram is offline
Vehicle: 2010 Ram 1500
Jim Ram is on a distinguished road
Mine did that when my truck was a week old.
2010 Ram 1500 Navigation
2007 Accord EX V6 Navigation
Old 11-08-2010, 07:35 PM
sprintertech's Avatar
sprintertech sprintertech is offline
Vehicle: 2010 RAM
Trim Level: BIG HORN
Color: AUSTIN TAN
Rep:16
sprintertech is on a distinguished road
This bulletin is supplied as technical information only and is not an authorization for repair. No part of this publication may be reproduced, stored in a retrieval system,
or transmitted, in any form or by any means, electronic, mechanical, photocopying, or otherwise, without written permission of Chrysler Group LLC.
THIS SERVICE BULLETIN IS ALSO BEING RELEASED AS RAPID RESPONSE
TRANSMITTAL 10-061 FOR 2010 DS RAM TRUCK 1500 PICKUP. ALL APPLICABLE
SOLD AND UN-SOLD VIN's HAVE BEEN LOADED. TO VERIFY THAT THIS SERVICE
ACTION IS APPLICABLE TO THE 2010 DS RAM TRUCK 1500 PICKUP, USE VIP OR
PERFORM A VIN SEARCH IN TECHCONNECT. APPLICATION OF THIS SERVICE
BULLETIN TO ALL OTHER SOLD UNITS IS BASED UPON THE CUSTOMER
EXPERIENCING THE SYMPTOM/CONDITIONS. ALL REPAIRS ARE REIMBURSABLE
WITHIN THE PROVISIONS OF WARRANTY.
SUBJECT:
Fuel Filler Close Out Housing Pops Out Of Sheet Metal
OVERVIEW:
This bulletin involves removing the fuel filler close out housing and file some material off of
the tabs that will not lock into place. If tab(s) are broken it will be necessary to replace the
fuel filler close out housing and it still may be necessary to filing some material off of the
tab(s) that will not lock into place
NOTE: Only remove material from tab(s) that will not lock into place.
MODELS:
2009 - 2011 (DS) RAM Truck 1500 Pickup
2010 - 2011 (DJ) RAM Truck 2500 Pickup
2010 - 2011 (D2) RAM Truck 3500 Pickup
NOTE: This bulletin applies to vehicles equipped with a single wheel rear axle only
built before August 9, 2010 (MDH 0809XX).
SYMPTOM/CONDITION:
The customer may notice that the fuel filler close out housing has popped out from the
body on one side or the other.
DISCUSSION:
If the Customer experiences the Symptom/Condition perform the repair procedure.
PARTS REQUIRED:
NUMBER: 14-005-10
GROUP: Fuel System
DATE: September 21, 2010
Qty. Part No. Description
AR (1) 55398620AD Housing, Fuel Filler Close out
INSPECTION PROCEDURE:
1. Remove the fuel cap.
2. Inspect the fuel filler close out housing (Fig. 1).
3. Is the housing dislodge at any tabs?
a. Yes >>> continue to Step #6
b. No >>> continue to Step #4
4. Pull out on the fuel filler close out housing 3 to 4 times with moderate force.
5. Did the fuel filler close out housing dislodge at any tabs?
b. No >>> Return vehicle to Customer or Inventory.
6. Remove the fuel filler close out housing by depressing the remaining tabs and pulling
out the housing (Fig. 1).
NOTE: Spraying the rubber with soapy water will aid in removal.
Fig. 1 Fuel Filler Close Out Housing
1 - Tabs (4 total)
7. Are any of the Tabs broken?
a. Yes >>> Replace the fuel filler close out housing. It still may be necessary to filing
some material off of the tab(s) on the new housing that will not lock into place.
b. No >>> continue to Step #8
14-005-10 -2-
8. Using a small file remove some of the material from the flat on the Tab(s) that would
not lock into place (Fig. 2).
NOTE: Only file enough material from the Tab to allow the fuel filler close out
housing to lock into place.
Fig. 2 Fuel Filler Close Out Housing Tab
1 - Tab
9. Install the fuel filler close out housing.
POLICY:
Reimbursable within the provisions of the warranty.
NOTE: No additional authorizations will be required for claim submission/payment.
TIME ALLOWANCE:
Labor Operation No: Description Amount
14-60-17-90 Inspect Housing, Fuel Filler Close out (C) 0.2 Hrs.
14-60-17-91 Inspect and Modify Housing, Fuel Filler Close out
(C)
0.2 Hrs.
14-60-17-92 Inspect and Replace Housing, Fuel Filler Close out
(C)
0.2 Hrs.
FAILURE CODE:
ZZ Service Action
-3- 14-005-10
CMR TUNED(tweeked),K&N DROP IN, MODDED AIR BOX, NITROUS EXPRESS 150 SHOT, ARH 1 7/8 LONG TUBES NO CATS, BORLA XR-1, PRO TORQUE 2800 STALL, 4.56 GEARS, MOPAR LSD, ADJUSTABLE REAR LOWER CONTROL ARMS RELOCATED UNDER AXLE, GREDDY CATCH CAN, STICK PEOPLE IN REAR WINDOW......12.97@108...SOLD
Old 11-09-2010, 08:27 AM
Shreve T's Avatar
Rep:27
SUBJECT:
OVERVIEW:
MODELS:
SYMPTOM/CONDITION:
DISCUSSION:
PARTS REQUIRED:
NUMBER: 14-005-10
GROUP: Fuel System
1 - Tabs (4 total)
14-005-10 -2-
1 - Tab
POLICY:
TIME ALLOWANCE:
(C)
0.2 Hrs.
(C)
0.2 Hrs.
FAILURE CODE:
ZZ Service Action
-3- 14-005-10
Thank you!!! I'm taking my truck into the dealer this morning... This has been drivimg me nuts.. It isn't going to get better with time either...
