Old 11-08-2010, 07:10 PM
cj1's Avatar
cj1 cj1 is offline
Vehicle: 2010 Dodge Ram1500, 2004 600RR
Trim Level: SLT Sport
cj1 is on a distinguished road
Default 35's on stock rims
Ok, so ive been looking and can't find a straight answer. will a set of 35's(federal couragia m/t 35x12.5R20) fit on my stock rims and not have any rubbing issues on the upper control arm(i dont care if it rubs the plastic in the wheel wells)?
i am leveled.
if it doesnt fit, what size rim spacer would i need?
Thanks Guys!!
Old 11-08-2010, 07:53 PM
bamasport's Avatar
bamasport bamasport is offline
Vehicle: 2010 Dodge Ram 1500 Crew 4X4
Color: deep water blue pearl
Rep:186
bamasport has a spectacular aura aboutbamasport has a spectacular aura about
I have 35x12.50x20 on stock rims right now. 6" BDS lift though, not leveled. I dont have rubbing issues, the person who installed it said i wouldnt rub but i put a 1/4" spacer in just to be sure.
3.92 rear axle, OEM 20" rims, 20% tint, Mopar wheel-to-wheel side steps, K&N drop-in air filter, LineX bedliner, OEM Tow hooks, Rampage Tailgate Light Bar, Borla Cat Back, 6" BDS lift, 35x12.50x20 Nitto trail grapplers, Custom painted interior, dodge slush mats
JON
Old 11-08-2010, 08:51 PM
cj1's Avatar
cj1 cj1 is offline
im only concerned cause i put my hand behind my stock tire and it barely fits between. So i dont want to order the tires and get skrewed over.
Old 11-08-2010, 08:59 PM
ScatPak07's Avatar
Rep:970
Since you have only a leveling kit be prepared to cut the crap out of the bumper and wheel well.
Old 11-08-2010, 09:24 PM
cj1's Avatar
cj1 cj1 is offline
is it really that close?
Old 11-11-2010, 08:44 AM
thomasspink's Avatar
thomasspink thomasspink is offline
Vehicle: 2004 Dodge Ram 1500 SLT 4x4
Color: Grey
Rep:76
thomasspink will become famous soon enough
on my 04 that is leveled, i have the stock 17's with 35x12.5 Feirce MT's
they do not rub at all
Old 11-11-2010, 09:41 AM
At the very least you will need a level kit. Also, rubbing inside will be a function of the tire section width you go with.
I have a 4" lift and 285/75RX18's with a +18 offset wheel. No rubbing. I could go to a 305 with that setup pretty easily and not worry about rubbing.
But if you are stock height with stock offset wheels, 265 or 275 section width tires will be the max for you and a 35" tall tire will rub at the bumper, possible the trailing edge of the wheelwell and definitely at the wheelwell liner unless you lift it some.
Old 11-11-2010, 06:21 PM
foxcrazy90's Avatar
foxcrazy90 foxcrazy90 is offline
Vehicle: 2008 dodge ram 1500
Color: electric blue pearlcoat
Rep:584
foxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to all
since your leveled i think 35's work,but i would look into using a 1/4" spacer to bring the wheel out!!!
NEIL KELLEY
2008 ram 1500 bighorn 4x4
2 1/2 level lift--hella 500ff grill lights--17x9 centerline grizzly-305-70-17 nitto terra grapplers--front air valance removed--tinted windows--custom audio system clarion vz401 head unit--pioneer 4channel amp and class D mono amp--memphis mclass door speakers--clarion dash speakers--kicker subs
Old 11-12-2010, 12:40 AM
Color: Grey
Rep:76
1/4" spacer doesnt really do anything unless you are just barely rubbing, they are just very small... i wouldnt run them unless i needed to, or unless i just got wheel adapter
Color: Grey
Rep:76
great avatar by the way
