Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 8.0 Liter V10
Custom Dodge Ram Performance Mods - Engine - 8.0 Liter V10 Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 11-08-2010, 06:48 PM
E.M.S. E.M.S. is offline
Vehicle: 94 2500 V10
Color: green
Rep:28
E.M.S. is on a distinguished road
Default oil pressure....
i bought a 94 ram 2500 with the 8.0 v10. drove it about 100 miles and found some transmission issues so i made plans to bring it to the tranny shop. mind you there were no other issues that i wasn't already aware of, the truck sat for over a year so i had some things to replace... we'll get to that in another thread.
the engine runs like a bull, smooth as can be with TONS of power when i want it.
well, on my way to the shop on thursday, only about 3 miles away, i noticed that the oil pressure gauge was bouncing all over the place. i stopped and checked the oil and it was clean, yellow and full.
i asked the shop to take a look and they said they could find nothing wrong and the oil looked fine, full and had no issues on their test drive.
I picked up the truck today and right away noticed the same thing as before, the pressure seems to move up with the throttle (as it should) and then starts to bounce, sometimes it drops to 0 and stays there for a few seconds or minutes, this happens at idle as well as when driving on the highway with the cruise control on. at one point it happend for i am assuming about 2 minutes until i could find a suitable place to pull over and lift the hood. when i lifted the hood, everything sounded fine, no knocking, the engine never lost power, never hesitated, and didn't seem to be overly warm when i lifted the hood. i checked the oil and it seems fine still. if i was causing some damage one would think that it would be harder to start the next time around but it starts right up and purrs like a kitten.
my questions are...is there a known issue with these pressure switches? and if so is this a normal symptom of a switch failing? could this be caused by a pretty substantial leak that i have in the oil pan gasket that would be changing the pressure in the system? to the best of my knowledge these engines have a mechanical oil pump, so i'm assuming that the pump is pumping. i am fixing the leak tomorrow, i have dumped a ton of $$$ in a short time trying to get this truck ready for plow season and don't want to replace a switch if there is something i can check to make sure that the switch is the problem or rule out the problem. i keep the level up on the oil despite the leak.
fixing the previous owners mistakes . . .
Old 11-08-2010, 07:18 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Welcome to the Z. Since you're changing the oil pan gasket, check out the pump and pan real good while you're at it.
The fluctuation you mention is common with a sensor/sending unit going out but could also be something in the oil pan is getting sucked up into the pump.
We have a lot of forums for all kinds of topics, so you shouldn't have any problems finding a place to post questions.
We LOVE pics of Rams.
Here's how to post them: http://www.ramforumz.com/forumdisplay.php?f=73
Brian:
Old 11-08-2010, 07:31 PM
Color: green
Rep:28
thanks, this is exactly what i was looking for and exactly what i thought might be the issue.
i know how to post pictures but it's dark out and i don't have any good pictures of the truck right now. it's a work truck with some cosmetic abuse, ha ha ha. paint peeling on the hood and tops of front fenders, doors have been "worked over" by someone who was practicing with bodywork.
another quick question, the oil pan looks very close to the crossmember under the engine. is there a secret to being able to remove the pan? will it come out without lifting the engine up? i have done this job before on several other vehicles. any surprises that i'm in for on this one? i don't have a garage at the house i currently live in so it has to be done outside.
thanks again for the quick reply. and i didn't realize that this was the engine mods forum, my bad.
Old 11-08-2010, 10:22 PM
moparmanicac's Avatar
moparmanicac moparmanicac is offline
Find em hot leave em wet
Vehicle: 12 RAM 1500 qc 4x4 HEMI
Trim Level: express
Color: bright silver
Rep:204
moparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura about
With my Dakota and the oil gague was never correct but tested the pressures manually and when I talked to one of my local mechanics who a Mopar nut (he owns multiple Rams Dakotas and Ramchargers) and he told me not to worry about dodges from the 90's and some other years have a habit of not reading the oil pressure right but everything being a ok, check the pressure manually before ya throw any parts at it
[SIGPIC] RIP 02 4.7 Dakota sport qc 4x4
RIP 05 Ram 4.7 rc 4x4
HELLO 12 Ram HEMI qc 4x4 and 94XJ
Old 12-26-2010, 01:27 PM
kremera kremera is offline
Vehicle: 1999 Dodge Ram 2500 V10 Gas
Color: RED
kremera is on a distinguished road
Hi,
I am having the same problem did you find the solution,
1999 v10
Old 12-26-2010, 02:21 PM
Color: RootBeer
Rep:1287
Originally Posted by kremera View Post
Hi,
1999 v10
Might I suggest you start your own thread on the question? Someone clicking on this old thread might not answer since its aged.
Brian:
Old 12-26-2010, 02:56 PM
I'd recommend to ya also to install a mechanical guage first and see what your oil pressure is really doin .
Old 12-26-2010, 04:06 PM
Color: RED
I checked the curb pressure it is at 12psi then at 57psi at 3000rpm, I have replaced the pressure sending unit it did not fix the problem. I have a 1999 V10 gas 2500 with 87k, oil is synthetic, no odd sounds, no leaks that I have noticed.
I will be driving down the road and the oil pressure will just drop out!
Is it a bad gauge, any ideas would be awesome!
Old 01-16-2011, 08:24 AM
Color: green
Rep:28
one of the mechanics at the transmission shop suggested that since the engine was running perfectly and smooth and quiet that there may be a build up of gunk at the sensor and it would be showing strange readings without actually being a problem. well wouldn't you know it, i removed the pressure sensor and it looked like hell with some visible build up on the actual sensor surface. i cleaned it the best i could then changed the oil again after a long warm up and highway drive and the oil looked like absolute garbage.
it must have been cleaning up all the old, (sitting around for a year and change) build up inside the oil passages. the truck still runs great and the oil pressure issue disapeared that same day. never replaced a thing other than the oil.
Old 01-16-2011, 08:36 AM
I would continue to do oil changes before their due to help get the garbage out of the system . You just don't know how it was taken care of previously .
