engine too cold too long - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 11-08-2010, 09:31 PM
Quiet Lunatic's Avatar
Vehicle: SRT-10
Rep:434
Default engine too cold too long
my check engine light recently came on, and the code reads that the engine runs too cold for too long. what causes this and is it worth worrying about? 2001 5.9l ram 1500
Old 11-08-2010, 09:33 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Welcome to the Z. Any check engine light that registers a code is worth investigating and fixing.
We have a lot of forums for all kinds of topics, so you shouldn't have any problems finding a place to post questions.
We LOVE pics of Rams.
Here's how to post them: http://www.ramforumz.com/forumdisplay.php?f=73
Brian:
Old 11-08-2010, 09:36 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PXR Black
Rep:2477
The one thing that comes to mind is that your thermostat is stuck open. If that were the case I would also expect that you are not getting any heat from the heater. That's all I can think of that would set that code, perhaps someone else will chime in with another possible cause. I would get it fixed.
sales@revelperformance.com
Old 11-08-2010, 10:14 PM
MaxPower1971's Avatar
MaxPower1971 MaxPower1971 is offline
Vehicle: 1993 250--1994 2500--2005 2500
MaxPower1971 is on a distinguished road
+1 on that...I was gonna say your temp sensor but since it says it's too cold......
MaxPower
Old 10-27-2013, 05:38 AM
Carvermitch's Avatar
Carvermitch Carvermitch is offline
Vehicle: 2002 Dodge Ram 1500 quad
Color: Garnet Red metelic
Rep:12
Carvermitch is on a distinguished road
Default wrong thermostat
Hi, I am in Montreal Canada and today the weather has got very cold ready for winter again.
When I started and drove off, it sounded a little louder in the exhaust than normal and it has just had a new muffler so it could not be that.
Then thermostatic fan always kicks in at start then goes away as soon as it warms a bit.
It seemed to be running ok but was slow changing into top gear and overdrive.
The temp gauge came up to less then a third of the way and after about 5 miles did not come any higher.
There seemed to bit a muffled bang under the hood I thought then the engine light came on. It was still running perfect and no other noise but the gauge was still low and we were getting very little heat from the heater and defogger.
I stopped and as luck would have it, had my engine code scanner in the truck so checked it and it came up 1281.
I cancelled the light and carried on, she ran perfect for the rest of the day.
During the summer I replaced the rad, water pump, thermo fan clutch, all hoses and thermostat but I replaced the thermostat with a 180 instead of a 195. Since then it has always run at about a third way up the gauge and no problem where before it was just under half way. It also seems to be using more gas than before to.
I think I will put a 195 back in and see what happens.
As we are getting into cold weather, I need the heater and don't want to damage my baby and cant afford to replace her at the moment.
Will keep you posted.
Old 10-27-2013, 07:07 PM
Rep:12
Purchased a 195 high flow thermostat to and was told that the computer was set in the factory to use a 195 for peek performance.
I am putting it in tomorrow so will see how it goes.
Old 10-27-2013, 10:03 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
Should just be the thermostat. My old truck would throw the 1281 code whenever it dipped below 80 or so outside with the 180* thermostat when I didn't run the ac.
Never had any problems with the 195* thermostat.
Old 10-28-2013, 07:22 AM
Rep:12
Thanks Brad, I am installing the 195 today so will see how it goes.
Old 10-28-2013, 10:22 AM
Rep:12
Had the 195 thermostat fitted and new coolant this morning along with oil and filter.
She now runs at just below halfway and it seems smoother and more responsive. The heater is 10 times better so I am now happy again.
Time will tell on the economy so lets see how she goes.
Old 10-28-2013, 02:54 PM
Rep:326
Thanks for telling us! Reps for that.
