Old 11-08-2010, 09:19 PM
Torq89 Torq89 is offline
Vehicle: 2005 Ram 2500
Color: Grey
Rep:87
Torq89 will become famous soon enough
Default 1 degree colder?
Would it be ok to run the NGK spark plugs in my truck that are one degree colder? I'm not very familiar with this. I just saw a member before that had the 2 degree colder plugs and some members were saying he needed to get it dyno tuned.
Old 11-08-2010, 09:24 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Why not just go with what the manufacturer recommends? The only time the fancy plugs come in handy is when building a racing motor with racing ignition and so on.
Brian:
Old 11-08-2010, 09:32 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
I have the NGK iridiums that are 2 degrees colder. You can go on NGK's site and it explains the difference. But basically the difference is each degree colder is for 100 hp. So lets say you have done 100hp worth of mods go with the 1 degree colder plugs and so forth. I didnt know this when i bought mine but i havent noticed anything running bad. I plan on doing some forced induction cam and heads in the future so i just got the 2 degrees colder ones.
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 11-08-2010, 10:32 PM
Color: Grey
Rep:87
Thanks for the input.
Old 11-08-2010, 11:32 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
meant really if your going to be on nitrous like i try to be :0. Do you know what retarded timing is look into that
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 11-09-2010, 12:55 AM
sprintertech's Avatar
sprintertech sprintertech is offline
Vehicle: 2010 RAM
Trim Level: BIG HORN
Color: AUSTIN TAN
Rep:16
sprintertech is on a distinguished road
youd run a colder plug if you were going to run a nitrous kit......a colder plug in general will have more problems because it doesnt get hot enough to clean and can foul faster.........
CMR TUNED(tweeked),K&N DROP IN, MODDED AIR BOX, NITROUS EXPRESS 150 SHOT, ARH 1 7/8 LONG TUBES NO CATS, BORLA XR-1, PRO TORQUE 2800 STALL, 4.56 GEARS, MOPAR LSD, ADJUSTABLE REAR LOWER CONTROL ARMS RELOCATED UNDER AXLE, GREDDY CATCH CAN, STICK PEOPLE IN REAR WINDOW......12.97@108...SOLD
Old 11-09-2010, 10:03 AM
Color: Grey
Rep:87
Ok i'll probably just go with the OEM plugs then. I still have another 10k miles before they need changed.
