Dodge Ram Decals
Old 07-06-2013, 04:57 PM
ESP ESP is offline
Vehicle: 2011 RAM 1500 sport
ESP is on a distinguished road
understandable. im excited to see what this thing will do.
Old 07-06-2013, 05:02 PM
Vehicle: 2010 Ram RCSB 4x4
Rep:561
Well I finally tracked down a matching AutoMeter Elite Series Wide Band
and a Fuel Pressure gauge to match my Boost gauge, test fit looks okay
The easy part is done...
Old 07-31-2013, 10:12 AM
Rep:561
Time for another update...
My Bud and I made a run for the border in his Cummins a couple weeks ago
(to save shipping/brokerage fees to Canada)
To pick up our L&M Customs built transmissions and ATS Torque Converters
It was 12 hours round trip, but only cost us $65 ea for diesel to get there and back on one tank.
UPS/FedEx charges would have been easily $400+ ea shipped to our door.
Picking them up at Sweet Grass Montana, AtTheBorderStorage fee $25/pallet, Customs fee at the border was $83 ea.
Mike didnt' have time to get them cleaned up on the outside, but we degreased them and painted them the following weekend ourselves easily enough.
Here's after paint ... Silver (BRH) and Copper(MGRAM)
Now I can finally get started on my Ripp Supercharger install!!!
While waiting for the paint to dry between coats I drilled my crank for the dowel pin
Next up, spark plug swap
Old 07-31-2013, 10:37 AM
Rep:561
Spark Plugs and Front Brakes/Rotors were done in an afternoon last Friday
...about 4 hours total working leisurely with several beer breaks (it was HOT)
Spent $240 for pads and rotors (Wagner)
I would have liked to step up to a 4 piston SSBC Big Brake kit, $1500
...but it wasnt in the budget right now, and as you can see I couldn't wait much longer...
With the Stopping power taken care of it was time to get the Go Power back on track...
Removed the grill so I could install my Ripp intercooler Rad, and more room to lay down on my engine to do the spark plug swap.
a light coat of black heat resistant paint so the aluminum rad wouldn't be visible through the grill...
Pump installed and routed the hoses to run to/from the heat exchanger
I matched up all the hardware, brackets, couplers and band clamps with the rest of my kit to make sure nothing was missing...
So it looks like injectors, PCV valve,MAP sensor, belt, boost/vac line tap for the little stuff
then everything else should go in within an hour or so... Awesome Kit anyone can DIY with basic hand tools.
Old 07-31-2013, 11:34 AM
JimsRamTruck2012's Avatar
Vehicle: 2012 Ram Express
Trim Level: Express Package
Color: Mineral Gray Matalic
Rep:327
Looks like some good work.
I would like to know how the brake pads work out for you. It seem like the pads that come from the factory are always nice and quite, but the next set of pads are always noisy unless you spend a boat load of money on them.
Old 07-31-2013, 12:16 PM
Rep:561
The Wagner Thermo Quiet are semi-metallic and considered a mid-grade pad.
and definitely live up to their name....no noise at all.
They were $30 cheaper than the OEM pads at the local stealership.
Old 07-31-2013, 02:20 PM
Rep:327
Thanks I'll have to keep that in mind for when I need to change the pads.
Old 07-31-2013, 04:28 PM
Rep:561
Wagner Part# MX1084
RockAuto has them for $35 (front set of 4 pads)
http://www.rockauto.com/dbphp/x,cata...ER_MX1084.html
Wagner Front Rotors are Part# BD126062 $42 ea (cheaper than getting the old ones turned/resurfaced)
http://www.rockauto.com/catalog/rafr...rtnum=BD126062
Old 08-01-2013, 11:39 AM
Warthog Fixer's Avatar
Warthog Fixer Warthog Fixer is offline
Vehicle: 2011 Dodge Ram 1500
Rep:20
Warthog Fixer is on a distinguished road
Black,
I just found this post and I NEED to know about your Carbon Fiber!!!! PM me when you get a chance. Thanks Much, Warthog
Old 08-01-2013, 03:11 PM
Rep:561
Originally Posted by Warthog Fixer View Post
Black,
What do you need to know Bud?
I'll try to remember, but it was 3 years ago and I am getting older
I just realized some of the links I provided on earlier pages for CarId are dead now.
You should still be able to navigate their site to find the Remin dash Kits for your year/model though
