Old 11-10-2010, 12:09 PM
GoTigers11 GoTigers11 is offline
GoTigers11 is on a distinguished road
Angry Bad Squeaking Under the hood!!
Ok....I have a bad squeak going on under the hood of my 99 dodge. I've replaced the belt (Gates belt), new tensioner, new idler, new water pump few months ago, and I've replaced the power steering pully but that didn't fix the squeak. What could be the cause of the squeak? I've used WD-40 and lithium grease on most of the pullys...squeak still wont go away. Kind of at odds with this one. Its really annoying and the squeak gets louder as the RPM's increase. ANY suggestions would be awesome!
Old 11-10-2010, 12:14 PM
Rep:1885
Is the squeak still there if you run the engine with the belt removed?
Old 11-10-2010, 12:31 PM
When the belt is off it does not squeak.
Old 11-10-2010, 02:20 PM
MaxPower1971's Avatar
MaxPower1971 MaxPower1971 is offline
Vehicle: 1993 250--1994 2500--2005 2500
MaxPower1971 is on a distinguished road
hmm...so when the belt is off there's no noise....do you have A/C??
MaxPower
Old 11-10-2010, 06:35 PM
aftershokk86's Avatar
aftershokk86 aftershokk86 is offline
Vehicle: 01 ram 1500 ext cab
aftershokk86 is on a distinguished road
mines doing this now to just started a couple days ago.
wondering if its the new fan clutch i just put in...hope not since id have to send it back to summit.
maybe the ac pulley, but it was working just fine, wonder why it would go out all of a sudden
mine also has new belt, water pump, new severe duty fan clutch
01Ram: infinity reference 6x9's/5.25's|kicker 12cvt|400w4channelamp|2500wmonoamp|
Old 11-11-2010, 01:39 PM
Yes...the truck does have A/C. I used WD-40 on the pullys (one by one) trying to find the problem one. If it is the A/C pully....would oiling it up not help?
Old 11-11-2010, 01:48 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
With the belt off can you spin the pulleys freely with no binding?
Brian:
Old 11-11-2010, 02:29 PM
Rep:1885
Dried out alternator bearings can cuse this problem.
Old 11-11-2010, 03:28 PM
Yeah it would...but not for long.....I'm thinking like Ramtech.....
Best bet is to take the belt off....and turn every pulley one by one, you may detect where it comes from. It's true that bad Alt bearings can do that, but I myself never seen one, but then again I don't work in a garage....
MaxPower
Old 11-23-2010, 08:44 PM
MoparMan76 MoparMan76 is offline
Vehicle: 98 Dodge Ram 1500
Color: BLUE
MoparMan76 is on a distinguished road
I wouldnt encourage spraying WD-40 at a pulley, just the thought of getting overspray on the pulley itself, it would just be temporary anyhow, and may cause some squeeling of a different type (belt slippage). I agree with them try taking the belt off and spinning them individually, keep in mind the squeek wont be loud at all as it would be when its under load and tension and may not remain detectable. another technique my grandfather taught me as a boy you could try, and dont mind me (oldschool) find a way to isolate your ears to each individual pulley such as a stethoscope, just watch out for moving parts and fanblades please.
If you don't want to stand behind our troops, feel free to stand In front of them!
