Old 01-02-2011, 10:30 PM
Virusmind Virusmind is offline
Vehicle: 1999 Dodge Ram Van 2500
Color: Green
Virusmind is on a distinguished road
Hey guys, Im having a very similar problem. I can definitely attest to not spraying any lubricant near your belt nor would I suggest belt conditioner. That just makes a mess.
My squeal starts after the engine is warmed up. I have spun every pulley by hand and they all turn smooth and quiet. A new belt is a temporary fix only to have the squeal return after a week or so. Squirting a little water on the belt instantly stops the squeal but only for a moment. I have also tried starting the engine with no serp belt just for a grin and of course there is no squeal then. I am lost. As the engine warms the squeal goes from subtle to continuous. PLEASE HELP!!!
Thanks.
Old 01-02-2011, 11:08 PM
Rep:2620
sometimes a belt tensioner pulley can do that
Old 01-02-2011, 11:19 PM
Color: Green
Could it be possible that a brand new tensioner that comes with a new pulley would make the exact same sound as the old one? I know its possible but seems unlikely.
So far I've been told alternator, water pump and fan clutch. I don't know, trying not to just throw parts at it. All pulleys spin free and quiet by hand, even when engine is hot.
Old 01-04-2011, 03:17 AM
speedymph1000's Avatar
speedymph1000 speedymph1000 is offline
Vehicle: 1994 Dodge Ram 1500
Trim Level: Laramie SLT
Color: Gloss Black/Silver
speedymph1000 is on a distinguished road
I have had personal experience with the alt. bearings being dry and believe me when I say it makes the sounds your talkin about. You can try takin Your alt. apart and pressing grease in the bearings, but its much easier to just replace it. Hope this helps You make a decision on what it is.
When in doubt use a hammer... The bigger the doubt the bigger the hammer!
Old 01-04-2011, 03:30 AM
Color: Green
Well, first off thanks to all who are trying to help. I threw another new serpentine belt on it last night and the squeal of course went away all day today. I'm sure it will be back in a week or two like always.
So do you think the tension of the new belt may be why something like the alt would quit making noise temporarily just to return in a weeks time??
Old 01-09-2011, 01:09 AM
ACRusty ACRusty is offline
Color: Green
ACRusty is on a distinguished road
Default 5.2l Squeak
If you figure this out please let me know. My 5.2l magnum is making the same squeak after it's warmed up. I've already replaced the belt with a new gates belt last week, squeak came back so today I put on a gates tensioner still squeaks after it warms up. I used a small plastic funnel with a rubber hose attached to listen and try to isolate the noise, sounds like it's coming from the idler, but it turns free as does everything else with no belt on it. Was wondering if it could be the alternator after it warms up and gets a load on it but it doesn't seem to change when I turn on the lights, any info will be appreciated thanks
Old 01-13-2011, 01:38 AM
Color: Green
Default 5.2l squeak
so I replaced the idler today,it still squeals so I took the belt off and ran it for a few seconds, it still squeals, must be internal, I have no idea what it could be now if anyone can help I would appreciate any info Thanks
Old 01-15-2011, 09:20 PM
panhead's Avatar
panhead panhead is offline
Vehicle: 1996 Dodge Ram 2500
Trim Level: WS
Rep:103
Check the 6-bolts for the crankshaft pulley.
Old 01-16-2011, 12:54 AM
Color: Green
I think this is because of the plenum pan gasket is leaking causing a huge vacuum leak, if I pull off the pcv hose it quits squeaking,I'm in the process of making a plenum pan,my son shear this 1/4" aluminum plate for me where he works, now I just need to trim the corners,cut out for the distributor and drill the holes. I ordered one from APS almost 2 weeks ago and I can't get any reply,no confirmation on order or shipping info filed a dispute with paypal we'll see what happens. I can't wait any longer need to fix this
Old 01-16-2011, 09:35 PM
aftershokk86's Avatar
aftershokk86 aftershokk86 is offline
Vehicle: 01 ram 1500 ext cab
aftershokk86 is on a distinguished road
fwiw mine turned out to be my water pump, even though i had receipts from the shop the PO took the truck to not even 3 months before. guess they scammed him, because the water pump looked corroded and the weep hole was leaking a little as well.
01Ram: infinity reference 6x9's/5.25's|kicker 12cvt|400w4channelamp|2500wmonoamp|
