Old 11-10-2010, 09:27 PM
edgar artecona edgar artecona is offline
edgar artecona is on a distinguished road
Question fuse for dash lights 15amp shorted num 35 i think problem started after towing traile
blowing dash fuse 15amp immediatly w all power off key lights etc problem stsrted after towing a trailer w electrical problems could it b trailer tow module i have had dealer reflash before
Old 11-11-2010, 11:05 AM
Rep:1890
You're blowing the dash lamp fuse even with the lights off? If this is the case and fuse 35 in the TIPM is the one blowing with the lights off, then you probably have a short in the A944 circuit. That's the red wire coming from terminal 8 of the C3 connector of the TIPM that leads to terminals 26 and 26 in the C1 connector in the cluster.
