Old 11-11-2010, 12:00 PM
dirty97ram dirty97ram is offline
Vehicle: 97 ram 1500 ext cab short bed
Color: bedliner
dirty97ram is on a distinguished road
Question sputtering and backfiring
ok so my tranny went like two weeks ago i pulled it had it rebuilt put it back in started it and it idles fine but when you put it in gear it bogs down then when you drive it it will be running fine but then all of a sudden it starts spitting an sputtering an backfiring no engine light on and it was running fine before the tranny was pulled anyone have any ideas?
Old 11-11-2010, 12:09 PM
Rep:1877
You didn't pinch the crank sensor wiring when reinstalling it, did you?
Old 11-11-2010, 12:17 PM
Color: bedliner
also i installed a new crank sensor an no the wires are not pinched i checked that was my first thought
Old 11-11-2010, 12:21 PM
Rep:1877
I can't imagine not doing a cam/crank relearn would cause that. Have you scanned the PCM just to make sure nothing is stored?
Old 11-11-2010, 12:24 PM
Color: bedliner
no my friend is suppose to bring his scan tool from work today to check
Old 11-11-2010, 12:55 PM
Rep:1877
If hhis will stream live data, you may want to check the MAP sensor while it's acting up.
Old 11-12-2010, 12:18 PM
Color: bedliner
ok so last nite we used two different scan tools and tested everything we could with them and everything seems to be working right according to my two friends who are mechanics. we seem to think it may be the pcm because a friend of ours had a chevy doin basically the same thing an thats what his problem was so today i going to get a pcm and see if it changes anything
Old 11-13-2010, 12:27 PM
Color: bedliner
so i changed the pcm and its still acting up we're not sure what to do now does anyone have any ideas
Old 11-13-2010, 12:38 PM
Rep:1877
Did you check the MAP sensor yet?
Old 11-13-2010, 05:56 PM
MaxPower1971's Avatar
MaxPower1971 MaxPower1971 is offline
Vehicle: 1993 250--1994 2500--2005 2500
MaxPower1971 is on a distinguished road
What crank sensor did you put in?? OEM or aftermarket??
Our trucks don't like aftermarket sensors very much.....
MaxPower
