2006 mega cab miss fire #7 cylinder - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 11-11-2010, 04:06 PM
marc thorpe marc thorpe is offline
marc thorpe is on a distinguished road
Default 2006 mega cab miss fire #7 cylinder
I have a dodge ram mega cab 2006/5.7 l Hemi 4x4
I have a misfire on #7 cylinder
we have inverted coils from 7-1 and coils are not the problem
On the #7 cylinder has 2 plugs/ the far plug closet to firewall is wet
we inverted the #7 and #1 cylinder plugs and seem plugs may not be the problem.
The check engine light comes on and can be reset,but motor seems to sputter the first few minutes and then settles
It seem to kick in (check engine light ) when reset upon start up
The fuel consumption on the overhead console is between 21 and 26 liters per 100/km
generally was 16 to 19 /100km with occasional 21-23 depending on the load
we are thinking it may be the injectors
what are your thoughts
Old 11-11-2010, 04:47 PM
Resident Technician
Rep:1915
Swap the injectors and see if the problem follows the injector. If it doesn't, either perform a compression test or remove the left side valve cover and check for a broken spring.
Old 11-12-2010, 07:25 AM
Tks Ram tech,we are gonna do a compression test today and see this am after overnight cool and see if check engine light turns on and how it runs
Old 11-15-2010, 03:01 AM
mega09 mega09 is offline
Vehicle: 2006 Dodge Ram MegaCab
Trim Level: Mega Cab
Rep:28
mega09 is on a distinguished road
let me know what you find out, my friends mega has the same issue. Happens every now and then. Mechanics thought it was spark plugs
Old 11-15-2010, 09:22 PM
TRIPLETED TRIPLETED is offline
Vehicle: 2006 Dodge Mega Cab 5.7 HEMI
Trim Level: SLT 4x4
Color: INFERNO RED
TRIPLETED is on a distinguished road
How many miles are on the truck? just wondered I have the same truck . How often to do you run some injecter cleaner thru the engine . What does the other plug look like? Good luck ! please post results Thanks TRIPLETED
