Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8
MOPAR DECALS
Old 02-08-2011, 08:42 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
That's true ^^^ Easier the engine can make power...
Old 03-27-2011, 03:19 PM
an4rchy's Avatar
an4rchy an4rchy is offline
Vehicle: 2001 Dodge Ram 1500
Color: Dark Blue/Silver 2Tone
an4rchy is on a distinguished road
I dont have a Dremel, can I use an angle grinder or grinding wheel and forget about the bevelling?
AN4RCHY
Old 03-28-2011, 09:59 PM
an4rchy's Avatar
Just trying to get the Throttle Body off now. Can anyone tell me how to take the cables off without breaking the plastic things?
Also there is a hose or something that is on the front near one of the sensors. how do I get that off too?
anyone have instructions or know the thread where I can find the info?
Thanks guys
AN4RCHY
Old 03-28-2011, 11:52 PM
alfonso318's Avatar
alfonso318 alfonso318 is offline
Trim Level: 1500 (5.9L)gas
Rep:42
alfonso318 is on a distinguished road
I just took mine off recently to do this and i didnt have too much trouble with the cables...i just used a flat head screwdriver and pry-ed at it till it released...the bigger issue was trying to get them back on after ward cause they have a snap into place...as far as the hose it front just pull that off...be careful if its brittle or else you'll be replacing a hose....i also just un-bolted (three bolts) the black contraption so i didnt have to disconnect all the cables and all that...hope that helps just make sure you put the cables back in the right place and dont forget your gasket for the throttlebody...goodluck and if u got more questions i'm sure someone else can chime in if this didnt help
Old 03-29-2011, 12:14 AM
an4rchy's Avatar
thanks Alfonso318. I unbolted the black thing the cables are attached to but they are still attached to the spring that controls the butterflies in the TB.
I will try to pop the cables off tomorrow with a screwdriver. hopefully they dont break. everything is just so brittle! I guess I have to pry all of them away from the TB towards the passenger side of the truck and not back towards the firewall? all three of them the same way?
AN4RCHY
Old 03-29-2011, 12:09 PM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
push them upward aiming the tab they are on out the bottom.
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 03-30-2011, 12:05 AM
alfonso318's Avatar
Rep:42
Nah i think two are going opposite each other in the front then the one in the back was a PITA to put back on...what i meant by pry i guess was push with your finger on one side and then push with the flat head on the other...prying might snap it...that's how i did it...good luck
Old 03-30-2011, 12:41 AM
xtremedurb00's Avatar
xtremedurb00 xtremedurb00 is offline
Vehicle: 2007 Dodge Ram 1500 QC BH
Rep:16
xtremedurb00 is on a distinguished road
I did this on mine as well. If you dont have a loud exhaust system, you can hear a nice deep roar when you get on it.
20% Tint,Magnaflow Y-Pipe & Exhaust,Jet 180 TStat,NGK V-Power,TB Ground,EFan,Superchips 3865, K&N 57
Old 03-30-2011, 02:31 PM
an4rchy's Avatar
Thanks guys. I got the TB off by pushing the cables up away from the TB.
I cut the silencers with a hacksaw blade and snapped the pieces off. then filed it down with a sanding plate on an angle grinder and rounded the edges with a half round file. then sanded it smooth, first with 100 then with 320 sandpaper. finally cleaner it up with carb cleaner and she is perfect!
To all the guys out there not sure about doing this because they dont think they have the skills, trust me I dont and I did it! Just take your time, dont rush and with help and advice from people on this forum it can be done easily. I dont have a Dermel, just use what you have lying around, it just might take a little longer. Have fun with it!
Thanks to everyone on here for all your help!
AN4RCHY
Old 04-07-2011, 10:55 AM
sdram03's Avatar
sdram03 sdram03 is offline
Vehicle: 2014 RAM 3500 Big Horn
Color: Maximum Steel
Rep:52
sdram03 will become famous soon enough
i soooo need to do it. maybe next winter when i don't drive it much, it'll be one of my projects.
thanks for the info. and yes, i would be one of those guys that worries about doing it right since i have hardly any experience putting "grinding" and "make it look pretty" together.
if you're gonna go, go with a smile!
2014 RAM 3500 Big Horn CTD CC 4wd in Max Steel
