Old 05-26-2011, 12:24 AM
ut20015.9 ut20015.9 is offline
Vehicle: 2001 dodge ram 1500
Trim Level: sport
ut20015.9 is on a distinguished road
so i was thinking about doing this mod as well i think i want to pick up a tb from the junk yard though. are the tb bore size the same 52mm? as long as it comes of a 5.9? or do they vary through the years?
Old 05-26-2011, 08:07 AM
ekmike ekmike is offline
Vehicle: 1999 ram sport
Rep:20
ekmike is on a distinguished road
Originally Posted by redneck View Post
go to the junk yard and find a ram van and take the one in that air cleaner. they all have it as long as it is a 94-01. thats what i did and it cost me 1 buck. lines it up perfectly.
ok cool thanks ill go check in the junk yard.
oh you probably have to find a longer bolt for it cause it is a bit short for a 3 inch air cleaner
ill check if it will work with one from a ram van.
[img]http://i680.photobucket.com/albums/vv169/92_IntegraGSR/Randoms/sigs/Mikesig1.jpg[/img]
Old 05-27-2011, 04:07 AM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
Cool
I might be wrong but I thought stock size was 48mm.
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
Old 05-28-2011, 12:49 AM
Trim Level: sport
really... i thought they were bigger...so maybe i will change my mind on the tb mod and actually invest a little coin and get a little bigger tb
thanks for the info
Old 05-30-2011, 01:29 AM
dodgeman2289 dodgeman2289 is offline
Vehicle: 97 ram 1500 ss/t 5.9
Trim Level: ss/t
Color: sunset burnt orange
Rep:44
dodgeman2289 is on a distinguished road
ya. getting a newer bigger one is nice but also check on ebay there was a guy from another forum who mods them and does really nice work. and alot cheaper than any other.. he will take it to a 50 or 52mm you order it.. when u get it you send him your and he will put 40-50$ back to you...
spectre cold air,sct tuner,ported tb,msdblaster coil,1.7 roller rockers,u/d pulley,180 stat,tranny cooler,transgo tfod-hd2 shift kit,pacesetter headers,cat delete,flowmaster super 10
Old 05-30-2011, 01:44 AM
Trim Level: sport
well it rained all day so i went ahead and did this mod along with installing a CAI. i will probibly buy a new TB down the road...im tring to save $ for a tuner, headers, high flow cat and new exaust
Old 08-01-2011, 08:49 PM
DaddyRAM DaddyRAM is offline
Vehicle: 1999 Dodge Ram 4X4 QC Long Box
Color: BLACK
DaddyRAM is on a distinguished road
I am in the process right now doing the throttle body. Slightly concerned with the stock air box (reinstalling I mean). Is it as much of a pain in the butt as it looks like it will be to get the gasket lined up?
Also, has anyone decided to half shaft the throttle plate shaft? Any gains? I would assume it would be as good as porting does because you're taking a major restriction out as far as i can tell.
Old 08-02-2011, 02:20 PM
Color: BLACK
Well it was a little bit of a pain getting the stock air box on, but that's fine. Only noticed maybe a small amount of high end torque but only in the 1 - 2 shift. Kicks a little harder on second gear engagement. Guess I need a cold air intake or open element like most of you are running? Also noticed a nice pool of oil inside the rear of the "keg". Time for that Hughes air gap!
Old 08-02-2011, 09:48 PM
White Lightening's Avatar
White Lightening White Lightening is offline
Vehicle: 2001 Dodge Ram Quad Cab 4x4
Rep:38
White Lightening is on a distinguished road
i did this to mine ...
I definetly noticed 2 big gains of cooler operating temps and not running so rich ... the only downside it makes me wanna put my foot in it more ... now to just make the "black mamba" intake
Drive It Like You Stole It ... Yeeeehaaaa !!!! 01 Ram or the 03 Neon Sport 5 spd
Old 08-20-2011, 12:56 AM
RamIndy RamIndy is offline
Vehicle: 96 Indy Ram, 96 3500, 01 3500
Color: Blue, Blue, Black
RamIndy is on a distinguished road
Gonna try on mine tomarrow
