Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8
Place your Ad Here!
Old 02-16-2012, 03:23 AM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
So did you figure it out yet?
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
Old 02-16-2012, 02:56 PM
barajastexas.5.2's Avatar
barajastexas.5.2 barajastexas.5.2 is offline
Vehicle: 1999 ram 1500
Trim Level: Laramie SLT
Color: dark green
barajastexas.5.2 is on a distinguished road
Good mod, I plan on doing this soon. Has anyone heard about the kegger(intake plenum) mod that consist of shaving metal of the runners inside the plenum. Its suppost to improve air flow and increase hp, torque and mpg. I checked my intake and the plenum is leaking so I am going to open it up anyway. Any ideas or input?
Old 02-17-2012, 05:45 AM
RAMING IT's Avatar
Rep:65
Post kegger
Yes I have as a matter of fact lol. Heres the thread on my mod.
http://www.ramforumz.com/showthread.php?t=80084
Old 02-17-2012, 11:58 AM
pl4life52 pl4life52 is offline
Vehicle: 2002 Ram 1500
pl4life52 is on a distinguished road
i got it fiiixed your the MAN!! that crap was bothering me every time id drive the truck.
THANK YOU!
www.YourFreeATM.com
Old 02-19-2012, 10:55 AM
jimphelps202 jimphelps202 is offline
Vehicle: 2001 dodge ram 2500 4x4
Trim Level: quad cab
Color: blue
jimphelps202 is on a distinguished road
did the same mod on a 650 double pumper on a mustang with an ATI procharger back in '95. It works
Old 02-19-2012, 09:29 PM
Dk808's Avatar
Dk808 Dk808 is offline
Vehicle: 02 Dodge 1500
Color: Blue
Dk808 is on a distinguished road
Very interested in doing this mod tomorrow... i have to get a dremel first but will take lots of pics to post step by step process and I will show all statistics right now i have an 02 ram with the 5.9 averaging 12.5 on highway cruising at 65-70. Hopefully we shall see improvement. Just wondering, with me doing this and having a CAI by K&N, do i need a computer now?
I do because I can, I can because I want to, I want to because YOU SAID I COULDN'T! -RJ
Old 06-10-2016, 10:24 AM
Audiobuff007's Avatar
Audiobuff007 Audiobuff007 is offline
Vehicle: 1993
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
Audiobuff007 is on a distinguished road
Smile Image links expired
Can you refresh the image links? I would like to see your work.
Originally Posted by bigtallcampbell View Post
So the 5.2 forum has a lot of talk about removing the air silencers from the throttle body (http://www.ramforumz.com/showthread.php?t=46431). I was a little skeptical, but after thinking about it, it couldn't hurt anything so I decided I should do it.
I took off my air hat and was surprised at how tall the silencers were. After seeing that, I began to think that there might be some legitimacy behind this. It was easily 1/4 - 1/3 of the total clearance between the top of the TB and the bottom of the hat.
So I whipped out my trusty dremel tool and hacked away...and hacked...and hacked. The port and starboard sides are thick. I ate through 6 cutting wheels.
After I put it all back together, I must say I was impressed. For a free mod, my throttle response was better and there's a nice sucking sound while at idle. The butt dyno felt a some more power and the torque seemed to hit a little lower on the RPM gauge.
Overall, I'd attribute this mod as about twice what you feel with a K&N filter on a stock intake. As we all know, mods compound each other, and I have quite a few mods already. So your mileage may vary.
A couple of pointers to you if you take this on (and I personally suggest it!)
-WEAR SAFETY GLASSES. Aluminum filings are not fun in the eyes
-Remove the IAC, MAP, and TPS. I've got a shiny new IAC where my dumbass knicked the IAC with my dremel tool.
-Belevel the sharp edges leading into the butterfly valves. This'll prevent a low pressure spot right at the edge of the valves
-Use Mother's aluminum and mag polish. If nothing else, you've already got it apart. Clean it!
-Taper the hard valley between the butterfly valves. This'll help air flowing across by removing 2 more low pressure zones
-Don't try and cut all the way through the silencers...this'll take forever. Cut about 15% out on both sides, groove the front and the back of it, and then take a pair of pliers to just break it off. You're going to have to sand it anyways and this'll save a load of time.
-Clean the entire TB top to bottom. It should be shiny...not black. You know who you are
-Don't touch the butterfly valves with the dremel. They have a very tight tolerance.
-Incase you skipped over number 1: WEAR SAFETY GLASSES
And the pics - these are after I was done. The 5.2 posting has a good before shot.
Side:
http://cid-d8c70a58f16de925.office.l.../TB%20Side.jpg
Top:
http://cid-d8c70a58f16de925.office.l...58F16DE925!390
And everything I cut off:
http://cid-d8c70a58f16de925.office.l...58F16DE925!389
Old 12-18-2016, 12:11 AM
skeer skeer is offline
Vehicle: 2002 Ram 1500 CC
skeer is on a distinguished road
Did anyone actually do this that's still around here? Can anyone attest to mileage differences?
