Question about horns.. - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 11-20-2010, 10:49 PM
cosbourn's Avatar
cosbourn cosbourn is offline
Vehicle: 2004 Dodge Ram QC 4x4
Rep:83
cosbourn will become famous soon enough
If you want loud, you have to have compressor, and tank, lines, fittings, and gauges. There are some electric ones that, IMHO, sound like crap. Can't beat a hornblasters kit, they have everything you need.
If you have it hooked up to your regular horn(e.g. steering wheel), and you get stopped for a sound ordinance for being too loud by a cop, they WILL give you a ticket guaranteed. You can't have it directly hooked up to your regular horn It has to be on a separate switch. Granted, it's illegal either way because it's violating sound ordinances, but if it's spliced into your pre-existing horn it'll get you in more trouble. something to think about for yah.
I personally wouldnt want it going off all the time when i want my reg horn (steering wheel one) because for it to work you have to have a compressor and tank with that compressor running NONSTOP drawing energy, and making noise just so you can have a horn. but if you go the electric route you wouldn't have to deal with this obviously, but you would sacrifice sound/sound quality.
I have looked into this idea for a while now and would love to be able to drop $500+ on a kit. but they are a little pricey. REAL train horns retail for over 1k, and thats just for the horn itself, nothing else. haha.
hope all this helps ya out.
Westin Ultimate Bull Bar w/ IPF 968CSG lights, Husky Mud Flaps, Bedlined GoRhino Dominator II steps, Bedlined Fuel Door, RBP Pedal-Covers, Clarion CZ300, Composite BFI (#71) w/ 8" Tall Amsoil Filter + K&N Drycharger Prefilter, AirRam Scoop, Flex-a-Lite 183, dumped Aeroturbine 3030XL
Old 11-21-2010, 01:22 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Here is my electric one, just compressor not extras
Old 11-21-2010, 02:23 PM
cosbourn's Avatar
Rep:83
haha! thats not to bad! how loud is it in person because im sure the camera's doing no justice.
Old 11-21-2010, 04:02 PM
Rep:2962
on my 1956 chevy 1/2 ton, i had had an electric horn setup, it had 2 electric air pumps & 4 horns, each a different length, i set it up on a 3 position momentary switch, center position was OFF, hold down in the top position & it only blasted 2 of the horns, hold down the switch in the bottom position & all 4 horns blasted. I had to make my own bracket, so that i would only have 2 holes in my inner fender, the horns were pointed down towards the road & slightly forward. There was no room between the radiator & the grill.
you can find some descent horns at this site, you can hear them too
http://trainhorns.net/
Old 11-21-2010, 10:55 PM
Rep:1930
Mine can be heard for a few blocks, worked great in the parade this summer
Old 11-22-2010, 10:04 PM
RamItAll's Avatar
RamItAll RamItAll is offline
Vehicle: 2002 Dodge Ram 1500
Color: Blue
Rep:85
RamItAll will become famous soon enough
my buddy has a hornblasters train horn. WOW ITS LOUD! i love it but hate the compressor. wolo horns arent too bad. when you see vehicles with the dukes of hazard horn its usually a wolo.
this is the wolo "bad boy" horn here
Old 11-26-2010, 11:21 AM
String13's Avatar
String13 String13 is offline
Color: Mineral Gray Metallic
String13 is on a distinguished road
what about the wolo mc splitter? inexpensive, no need for an air system and comes with the small compressor..but no mounting hardware. any suggestions on how to install it under the hood?
Old 12-27-2010, 05:04 PM
BIGDROCH's Avatar
BIGDROCH BIGDROCH is offline
Vehicle: 2007 2500 Megacab 5.9L
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
Rep:37
BIGDROCH is on a distinguished road
If you want a horn with some balls then you'll just need to spend the coin and get a complete kit. You want the big train horn sound but you're not going to get it trying to cut corners or buying other stuff for less. If there was a way, then everybody would be doing it. Train Horns are not direct bolt in, they're Completely custom to install. Buttons, PSI switches, lots of wiring, an Air Tank or tanks, a Solenoid or air valve, air lines, brass fittings & Plugs, a compressor, and the horn. It's all gotta be mounted somewhere and takes near a full day to install it depending on how detailed you want to get. Mine took a weekend of planning, building, and Installing. My point is if you want the BIG legit Train Horn sound, you have to spend the money and if you're a total noob, then you're probably not going to be able to install it yourself.... at least you're making it sound like you won't be able to...
Lots of stuff...
Old 01-28-2013, 05:06 PM
Blue07 Blue07 is offline
Vehicle: 2007 Dodge Ram 1500 Big Horn
Color: Blue
Blue07 is on a distinguished road
I too am new to the aftermarket horns and have a Wolo myself. However the wiring looks tricky. It looks like Ill have to cut the wires and use my own connectors. I have 2007 1500 big horn with the dual factory horns with two wiring harnesses. Total of 4 wires all together, not sure where to start. Anyone have any advice? Thanks guys.
Old 01-28-2013, 06:18 PM
Color: Blue
Default wolo horn
I was able to mount the wolo horn and keep the low tone horn from the factory. sounds pretty good, some cuts and splices but simple wiring. Let me know if anyone needs help with Wolo. Thanks
