Old 11-12-2010, 10:20 PM
TRIPLETED TRIPLETED is offline
Vehicle: 2006 Dodge Mega Cab 5.7 HEMI
Trim Level: SLT 4x4
Color: INFERNO RED
TRIPLETED is on a distinguished road
Angry tires won't stay balanced
When I put Michelin AT2 on my 4x4 Mega cab 5.7 Hemi with 82000 miles - eversince then these tires won't stay bal - had the tire checked - rims are true but at 68 to 75 the truck shakes bad seems like the tires are loose . Pain in the -ss since I drive 106 round trip to my shop . HELP - HELP - thanks - TED
Old 11-12-2010, 10:31 PM
You don't have anything added to the tires like "Slime"" do ya ? That could effect the balance . But once their balanced that should be good to go . Maybe the shops balancer isn't right . Try someone else .
Old 11-12-2010, 10:55 PM
Rep:2657
Dodge had done all my tire work, checking pressures, rotating tires, etc.
when i had a service right around 23,000 miles, i was told that it was time to rotate the tires again, so i told them to go ahead & rotate. The next day i had a job, i drove about 400 miles & i went into the dealership & told them the tire shake was so bad that it caused my hood to shake & made my arms a bit tired. They took it into the shop the next day & i guess tried several different things, i saw the tech drive by on the street several times. Then i was told that they had fixed it, as soon as i hit the highway, i knew that they had not fixed it. I drove to Discount Tire, told them what had occurred, the whole story. I then asked their opinion, they said that they would have to check it out, but, i was leaving on vacation the next day & had them re-rotate the tires & i had no problem.
Now i am going back to Discount Tire & i am going to have them pull ALL the weights on those 2 tires & re balance them from scratch
I have not hit the sides of the tires or rims against anything, so they can't be damaged, i have the 20" chrome clad rims & tires that came with the Ram
Old 11-13-2010, 10:26 AM
gbb's Avatar
gbb gbb is offline
gbb is on a distinguished road
Default Tire balance
Never been a fan of Michelin tires but they may not be the problem.
Try to find a shop that has Hunter GSP9700 road force balancer. Hunter's web site has the locations. It is absolutely the best way to balance a tire. Out of round tires are spotted immediately.
Also, I live in Houston and Discount Tire absolutely sucks. Years ago, they were fine, but not anymore. There are 3 stores close to my home and I would not go to any of them again. If I wanna get screwed out of that much money again, I will buy a hooker.
Old 11-13-2010, 10:30 AM
Rep:1885
The Coates XR1800 series balancers can do the same thing; they look for radial and lateral runout and match balance the tire to the rim.
Old 11-13-2010, 09:47 PM
ScatPak07's Avatar
Rep:970
If the tires are balanced and the truck still vibrates you may have to look at the front Hubs.
