Old 11-14-2010, 12:09 PM
Epitonic Epitonic is offline
Vehicle: 2008 Dodge Ram 1500 4x4
Epitonic is on a distinguished road
Default 2" level kit
New to this forum, hope i can get some fast help.
I just ordered a 2" leveling kit (Torsion key) for my '03 dodge ram 1500 off-road edition. Buddy at the custom shop said it will level my truck with no problems, but it seemed he didn't entirely know what he was talking about humming and hawing. so...
Q: After they install the 2" torsion key will it level my truck?
Also i just ordered 18x9 KMC XD series monsters with +18 offset = 5.71 backspacing.
Again, at Wheel Pros Customs across the street i asked and asked if FOR SURE the wheels will fit my truck, and if the wheels will fit my truck with the 33x12.5 toyo m/t tires with my 2" leveling kit.
Q: WILL THEY FIT?!?!
I need to know ASAP, my truck goes in next monday.
Old 11-14-2010, 11:32 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
the first question answer is yes second one cant help you with sorry
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 11-15-2010, 01:44 AM
GregRam1500's Avatar
GregRam1500 GregRam1500 is offline
Vehicle: 2006 Dodge Ram 2500
Trim Level: Quad Cab Short Bed
GregRam1500 is on a distinguished road
Leveling kit will fit your truck. And 2 inch level kit only exceed no more than 35 inch tires so 33" should fit your truck with level kit.
Old 11-15-2010, 03:56 PM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
They should fit just fine and it will level your truck. I had mine leveled and it raised the front like 1.75 inches. you'll be fine.
Old 11-16-2010, 07:18 PM
Thanks fellas
Old 11-21-2010, 09:19 PM
pieece's Avatar
pieece pieece is offline
Vehicle: 03 Dodge Ram 1500 QC 4X4 5.7H
Color: Two Tone - Grey/Silver
Rep:38
pieece is on a distinguished road
I have the leveling kit (2") and the company I had installed them crunk them up. I got the complete 2" that it said.
The rims will fit. Not a problem.
I'm running 285/70 17 Because Rhino linings said 33s might scrub the struts a little and will decrease the turning radius quite a bit.
17" Eagle Rims/2" Leveling Kit/33" Nitto Terra Grapplers/Billet Grille/K&N CAI/SUPERCHIP/-5% Tint/Black Chrome Running Boards/Black Chrome Light Bar/Behind the Grille Running lights - HALOS/4 100W KC Daylighters - Black/Fire-Ice Bar/Recon Smoked LED Cab Lights/Electronic Safe/
Old 11-22-2010, 06:57 AM
Citizen's Avatar
Citizen Citizen is offline
Vehicle: 2004 Ram Off Road 4x4 Hemi
Color: Deep Molten Red Pearl Coat
Citizen is on a distinguished road
You should be good to go with 33x12.50s but be sure to get the front-end aligned when do the leveling kit
Old 11-22-2010, 09:59 AM
I did a 2" Daystar spacer on my Ram and have 315/70/17 BFG's (35's) . I need to order a adjustable track bar because I have a straight front axle . Once thats on I shouldn't experience much tire rub anymore . The tires presently rub on hard right hand turns because the front rear has shifted over to the left side of the truck because of the lift . Make sure you have the front end realigned .
Old 11-23-2010, 08:55 PM
ScatPak07's Avatar
Rep:970
With the level you will be able to fit some 33" tires. The only thing I noticed about the wheels you want is the offset. You should look for a negative offset wheel. The negative offset will help fit a bigger tire since it brings the tires out away from the truck. It will bring the tires out of the wheel wells which also gives it a mean look. If you can go with -12mm offset it would be good.
