Old 11-17-2010, 05:47 PM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
go on ebay and buy a $20 set of canbus foolers. i got a set and it works like a charm.
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
Old 11-18-2010, 01:25 AM
sprintertech's Avatar
sprintertech sprintertech is offline
Vehicle: 2010 RAM
Trim Level: BIG HORN
Color: AUSTIN TAN
Rep:16
sprintertech is on a distinguished road
cant offer no other suggestions but ^^^^^^^
other option is to buy the kit aac sells...its good stuff and it works.....but pricey!
i had this problem on 07 and up sprinters...on the cab and chassis some customers would put led tail lamps....the bcm would turn them off and put the lamp out light on becasue the resistance was too low......same problem you have.....an inline resistor would work but if you hurt something it will be costly......
as for the tpm light coming on id have to guess your ballast is too close to the antenna....move the ballast and see what happens....g/l
CMR TUNED(tweeked),K&N DROP IN, MODDED AIR BOX, NITROUS EXPRESS 150 SHOT, ARH 1 7/8 LONG TUBES NO CATS, BORLA XR-1, PRO TORQUE 2800 STALL, 4.56 GEARS, MOPAR LSD, ADJUSTABLE REAR LOWER CONTROL ARMS RELOCATED UNDER AXLE, GREDDY CATCH CAN, STICK PEOPLE IN REAR WINDOW......12.97@108...SOLD
Old 11-18-2010, 10:55 AM
slamdram's Avatar
slamdram slamdram is offline
Vehicle: 2010 dodge ram 1500 quad cab
Color: Brilliant Black crystal pearl
Rep:233
slamdram has a spectacular aura aboutslamdram has a spectacular aura aboutslamdram has a spectacular aura about
Exclamation
its none of those problems you have to wire in a relay for both ballasts! the same thing happen to my buddies truck its weak/low voltage coming out of the factory plug on the dodges!!! once you wire in a relay it will not back feed voltage into the ballasts and you will be golden!!!!
SlamdRam
Old 11-18-2010, 11:28 AM
Vehicle: 2010 RAM
Color: AUSTIN TAN
Rep:16
the voltage will be low if tested with the headlamp harness connector disconnected......but if you were to test the voltage on the positive side with the factory headlamps powered up you would find that the voltage is normal.....you make my point for me.....when the tipm does not see the correct voltage it shuts the circuit down...so all you are seeing is a checking voltage if you will....but you are correct....a relay using battery voltage for load side and the headlamp control circuit on the control side of the relay would work....lol.....a relay has a resistor on the control side....pull the cover and you will see it....it prevents the spike (feedback) when the coil in the relay shuts down and provides some resistance....
same as a one way resistor from an a/c clutch control on a older vehicle would work.....no return to the tipm when you power down and enough resistance to make the tipm happy......
Old 11-18-2010, 04:45 PM
slamdram's Avatar
Rep:233
exactly you just got a lil bit more technical than i did!! LOL
SlamdRam
Old 11-19-2010, 09:17 AM
Btreat003's Avatar
Btreat003 Btreat003 is offline
Vehicle: 2010 Dodge Ram Sport Crew
Rep:26
Btreat003 is on a distinguished road
i was told when i ordered my HID's that since dodge has such an advanced computer, you will need relay's and cancellers for the high and low beams, but not the fogs or they will basically operate as you are describing ...... haven't received my lights yet so i can't tell ya.... hope this helps
Old 11-19-2010, 05:10 PM
My ss got a ls's Avatar
My ss got a ls My ss got a ls is offline
Vehicle: 2010
Trim Level: laramie
My ss got a ls is on a distinguished road
Where is the tpms antenna
If you cant dodge it ram it
Old 11-20-2010, 11:54 AM
Vehicle: 2010
Trim Level: laramie
So after I got them in found out the drivers side bulb went bad lol so now I am going to wait for a new one and I should be good with the relay harness
Old 11-22-2010, 07:26 PM
Vehicle: 2010
Trim Level: laramie
I got my new light going to install it tonight and see whats going to happen wish me luck
Old 11-22-2010, 11:16 PM
Vehicle: 2010 RAM
Color: AUSTIN TAN
Rep:16
G/L
