Old 11-29-2010, 09:59 AM
My ss got a ls's Avatar
My ss got a ls My ss got a ls is offline
Vehicle: 2010
Trim Level: laramie
My ss got a ls is on a distinguished road
So after they been in for a week they work fine so far and I can actually see lol.
If you cant dodge it ram it
Old 11-30-2010, 02:52 AM
AKFossil's Avatar
AKFossil AKFossil is offline
Vehicle: 2010 Dodge Ram 1500 Crew Cab
Color: Inferno Red
Rep:57
AKFossil will become famous soon enough
Hmm
On my Ram I installed a HID kit that required a Capacitor/relay set up. How it worked was a relay had a direct battery connection, connected both Ballasts, and a capacitor that plugged into the driver side low beam connector. This set up according to the HID seller allows me to run my automatic lights or run them normally without the truck shutting off the lights due to low voltage.
2010 Dodge Crew Cab Inferno Red: HID Low Beams & Fog Lights 6000K, LED Interior Lights, LED License Plate Lights, Black Nerf Bars, AVS Bug & Window Deflectors, K&N Drop In Filter, WeatherTech Floor Mats, Goodyear Wrangler Silent Armors, MagnaFlow Muffler
Thinking about: New Wheels, and leveling kit.
Old 11-30-2010, 11:05 AM
Vehicle: 2010
Trim Level: laramie
Yes the relay is the way to go
Old 12-06-2010, 08:47 PM
sprintertech's Avatar
sprintertech sprintertech is offline
Vehicle: 2010 RAM
Trim Level: BIG HORN
Color: AUSTIN TAN
Rep:16
sprintertech is on a distinguished road
so i finally got around to doing mine.....i dont have quad lights so i went with a bi-zenon kit....i also ran a relay set up with power coming from b+ and a resistor on the low beam circuit to the capacitors......no problems so far but the high beams have a tiny bit of flickering if you have the lights shinning on a wall where you can see good......im gonna put a resistor and the high side to see if it clears up......now i gotta do the fogs!
CMR TUNED(tweeked),K&N DROP IN, MODDED AIR BOX, NITROUS EXPRESS 150 SHOT, ARH 1 7/8 LONG TUBES NO CATS, BORLA XR-1, PRO TORQUE 2800 STALL, 4.56 GEARS, MOPAR LSD, ADJUSTABLE REAR LOWER CONTROL ARMS RELOCATED UNDER AXLE, GREDDY CATCH CAN, STICK PEOPLE IN REAR WINDOW......12.97@108...SOLD
Old 12-06-2010, 10:33 PM
AKFossil's Avatar
Color: Inferno Red
Rep:57
Fogs were easy plug and play!
