Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Place your Ad Here!
Old 11-15-2010, 12:57 AM
hckyplyr hckyplyr is offline
Vehicle: 2011 Dodge Ram 1500 Bighorn
hckyplyr is on a distinguished road
Default 2011 Ram Bighorn Uconnect...HELP!!!
Hi Guys,
I have done a search on the problem I'm having, and my problem seems to be unique compared to the other problems. My dad just purchased a 2011 Ram 1500 Bighorn with the factory installed Uconnect. He has a motorola razor phone. We paired the phone, set the priority, etc etc. When my dad MANUALLY turns on his bluetooth in the truck, incoming phone calls work by coming through the uconnect. Also, when making outgoing calls, it works great. Clarity and everything else is great. Here's the problem though. If my dad doesn't manually turn his bluetooth applicator on (on his cell phone), the uconnect wont automatically connect to his cell phone. It has connected automatically when he gets in the vehicle a couple times, and will then automatically shut off when he turns the ignition off and opens the door, but this ONLY happens probably 1 out of 10 times. What are we doing wrong? Basically, we want the uconnect to automatically connect to his cell phone when he gets in the vehicle, without him manually turning on the bluetooth function on his cell. Thanks for all your help guys!
Old 11-15-2010, 01:00 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Welcome to the Z. Does he have the bluetooth on his phone set to automatically connect to the Uconnect? Its in the phone's bluetooth settings. It also takes a about 30 seconds for the Uconnect to connect after the radio/truck are turned on.
We have a lot of forums for all kinds of topics, so you shouldn't have any problems finding a place to post questions.
We LOVE pics of Rams.
Here's how to post them: http://www.ramforumz.com/forumdisplay.php?f=73
Brian:
Old 11-15-2010, 02:22 AM
JRI JRI is offline
Vehicle: 2010 Ram Crew Cab
Rep:14
JRI is on a distinguished road
I am just a little confused by your description of the problem.
You say your dad has to manually turn on the blue tooth on his phone. The problem with that is that if the blue tooth on his phone is not on then Uconnect will not know the phone is there.
You further say that when he shuts off the vehicle and opens the door the Uconnect shuts off. The problem with that is that if you have turned the vehicle off then you have also turned off Uconnect.
As far as inconsistant service goes I am having the same problems with mine. I would check the list of "approved" phones from Uconnect. Apparently if your specific phone is not on the list there is nothing to be done if it does not work correctly.
Old 11-15-2010, 11:57 AM
Turbovsix's Avatar
Turbovsix Turbovsix is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
Rep:85
Turbovsix will become famous soon enough
Hmm, I"m assuming you've checked this, but make sure your phone is "discoverable" - it's a setting in the phone's Blue Tooth setup.
Rich -
2010 Dodge Ram 1500 SLT Big Horn, Crew Cab HEMI
2012 Jeep Grand Cherokee Limited
Old 11-15-2010, 12:13 PM
UN4GTBL's Avatar
UN4GTBL UN4GTBL is offline
Vehicle: 2007 Dodge Caliber
Rep:41
UN4GTBL is on a distinguished road
There should be a setting on the cell phone that allows the bluetooth to stay on or turn on when another bluetooth device is in range. I turned my bluetooth on permanently on my BB and i never have a problem with it.
2007 Dodge Caliber SXT - 1.8L I4 & 5-Speed Manual
2011 Dodge Grand Caravan SXT Plus - 3.6L V6 & 6-Speed Auto
Wanting a new Ram...
Old 11-16-2010, 11:13 AM
KGVette's Avatar
KGVette KGVette is offline
Vehicle: 2010 Ram 1500
KGVette is on a distinguished road
Not sure but I think the Razor is fairly old in terms of cell phones so might want to upgrade. I have a droid and if I have blue tooth turned on its stays on and just automatically syncs whenever I get in. Now I dont always leave it set on on my phone as having bluetooth constantly turned on will drain your battery faster on your phone.
Old 12-09-2010, 12:48 AM
LightZone LightZone is offline
Vehicle: 2007 Dodge Ram 1500
Rep:38
LightZone is on a distinguished road
Send a message via ICQ to LightZone
I am having the same problem. I just got my 2007 Ram, and before had a 2006 Charger with U Connect. The phone was automatically recognized when I got in the car and started it up. My Ram needs to have me link up manually using the phone each time. Same phone as with the Charger and I have not changed the settings on my phone. Any thoughts would be appreciated!
Old 12-09-2010, 01:20 AM
Rep:2890
i have the Motorola RAZR V3, it works perfectly
i just went to the phones tool box, opened it, then i went down to Connection, selected Bluetooth, clicked Audio Devices to see if any phones were connected, the old trucks device was, it was a Parrot Device & i no longer had that so it was deleted.
then i clicked Add Device to see what it was, it was empty.
Then i went out to the Ram & turned on the key, the radio came on
Then i hit FIND ME & the phone went into Discover Mode, the Uconnect showed up, i finished out the sequence with the phone & the Uconnect, now when i am 35 feet away from the Ram & the key is still on, the phone stays connected to Uconnect, i step a couple more feet away & it disconnects automatically, i step back into the 35 feet & they reconnect.
When i shut off the key, the phone is automatically disconnected, when i walk out to the Ram & turn on the key, the phone connects automatically.
I never change the phones settings.
Only problem that i have had, if i am within the 35 feet & have the key turned on, i have to get back into the Ram to answer through the microphone, OR go into the phones Bluetooth setting & disconnect it manually, or step further away from the Ram & out of range
All the APPLE products are a whole different story, Iphone, Ipod, etc.
By the way, if you have the Iphone 4, forget it until Apple changes frequencies
Hope this helps
Old 12-09-2010, 01:51 PM
Rep:38
I too have my problem solved. In my phone, under Bluetooth Devices, I had 2 U-Connects, one from my old Charger and the other from my new Ram. As soon as I deleted the older "Charger" version, U connect works as expected. It automatically finds my phone when the truck is started, and disconnects when I shut the truck down. Obviously the 2 U-Connects in my phone created a conflict, causing the neither to be automatically recognized. I hope this helps.
Old 12-10-2010, 01:21 AM
GRam's Avatar
GRam GRam is offline
Vehicle: 2011 Ram
GRam is on a distinguished road
I had the dealer install mine after purchase, and it fails to recognize my blackberry 4 or 5 times out of 10.
As an aside, anyone else have sound issues? Almost every caller says the sound from me has an atrocious echo. I've tried adjusting where the mic is but no change.
2011 HD StreetGlide, 103" 106 TQ
2012 Polaris Assault 800 101 TQ
2011 Cummins 800+ TQ
Torque, it's what moves you...
