Old 11-16-2010, 02:14 AM
MOPAR stallion's Avatar
MOPAR stallion MOPAR stallion is offline
Vehicle: 1997 Dodge Ram 1500
MOPAR stallion is on a distinguished road
Default Timing belt and water pump
Hey fellas,
i was wondering if any of you knew what the rated mileage on our engines means its time to change the timing belt and water pump? i think for most engines its 80,000?
Also whats the easiest way to check and see if it has already been done? my truck has just over a 100k on it and the previous owner had it for 3 years but only put 7k and doesnt know if it got changed before that.
any help is greatly appreciated
thanks all
Old 11-16-2010, 09:11 AM
rancherman's Avatar
rancherman rancherman is offline
Vehicle: My DD is '97 Dodge Ram 1500
Rep:171
rancherman has a spectacular aura aboutrancherman has a spectacular aura about
I'll go out on a limb here, (and get shot off too)
I have not been in the timing case on mine yet (if it ain't broke...leave it alone)
every LA engine I worked on in the '70's had a CHAIN to drive the cam. I can't imagine changing this design.
That being said, unless previous owners never changed oil.. I would 'IMO' say 200K is closer to service life. All my 5.9's have at least 200,000... and one made it to 250,000 before I swapped it for a fresher one. (timing chain was not an issue for doing it)
The water pump should be almost the same here too.
Any leaks around shaft... noises.... fan 'run-out'? ( be aware the fan clutch will 'give' a little while checking) it's best to take belt off to check bearing play.
I would say you are good for some miles yet!
Old 11-16-2010, 09:33 AM
tomcatg tomcatg is offline
Vehicle: 1998 Dodge Ram 4x4 Sport
tomcatg is on a distinguished road
I had mine replaced at around 160k or so. I had an intake gasket leaking and when that was getting repaired I decided to do the water pump, timing chain etc. I wasn't having any problems just preventive maintenance type of thing.
Old 11-16-2010, 09:37 AM
Rep:1885
You don't have a timing belt, you have a chain. Water pumps only need replacing in the event of a failure.
Old 11-16-2010, 12:23 PM
oh ok well that definitely is good to know. the last car that i had as a driver was a honda with a timing belt which explains why it would need to be changed at 80k but a chain must be alot stronger!
Old 11-16-2010, 12:53 PM
Rep:1885
They are. Granted even a chain will develop some stretch over a lot of miles but unless it's causing a problem or the engine is being rebuilt, there's no reason to replace it.
Old 11-16-2010, 01:33 PM
jpaul51's Avatar
jpaul51 jpaul51 is offline
Vehicle: 2009 Ram 2500 Megacab
Rep:167
jpaul51 has a spectacular aura aboutjpaul51 has a spectacular aura about
Good information here! Thanks Ramtech.
2007 Ram 1500 QC - SOLD and bought a 2009 4x4 Megacab 2500 with 6.7 Cummins. Full Sinister EGR/Throttle Valve/dpf deletes, 4" Turbo back exhaust, Banks cold air intake, EFI Live tuning by Anarchy Diesel running 100hp Street tune. Peragon bed cover.
Old 11-16-2010, 04:09 PM
RAMBOW39 RAMBOW39 is offline
Vehicle: 1999 ram 1500 quad cab sport
Color: green
RAMBOW39 is on a distinguished road
182000 milesb on my third waterpump previous two failed factory one made it to 90000 then put a reman from napa (junk) now i have one from advanced auto new. really dont know why my truck goes thru them so much.
Old 11-16-2010, 04:11 PM
Rep:1885
If your first one made it 90k and you needed two more to make it to 182k, then my guess is the aftermarket pumps are crap.
Old 11-16-2010, 09:40 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Spend the extra $25 and get a new pump, instead of a reman. Lifetime warranty instead of 1 year. Wouldn't trust my cooling system to a reman part.
