Old 11-16-2010, 08:35 PM
jmr's Avatar
jmr jmr is offline
Vehicle: 2014 RAM 1500 Express RC 2WD
Trim Level: Express Regular Cab
Rep:74
jmr will become famous soon enough
Default Skid Plate Info
On my 2010 RAM 1500 I installed the front axle skid plate part 52022048AH from mopar-wholesale.com. To mount it requires 4 - M8x1.25x30mm bolts that I bought from from Autozone. The skid plate cost $30 and shipping was $10, which is a cheap alternative to the factory kit part 82210014 that consist of the same skid plate with 4 self tapping M8x1.25x30 bolts for around $99.
The front skid plate is also used for the tranfer case too but you'll need to buy a frame crossmember to fasten the back of the skid plate. The part number for the transfer case kit is 82210021 and it's around $115. I'm not sure about the part number for the crossmember but it cost $38 and you'll need 8 - M8x1.25x30 bolts.
BTW - The skid plate is the same one used on the 2006+ RAMS.
'14 RAM 1500 Express RC 2WD 3.6L 8SPD 3.55 W/LSD uConnect 5.0 Red Calipers, K&N Filter, 4" AirBox Intake Tube, Cabin Air Filter, Upper Glove Box, Hemi Dual Exhaust, Leather Steering Wheel w/Radio Controls, Mopar Bed Liner, Lund Genesis Tri-Fold Cover, 22MM OEM Rear Swaybar, Mopar ParkView Camera
Old 11-16-2010, 08:55 PM
You should of checked with our vendor "Mopar Online Parts" . They too have part# 52022048AH for $30.00 .
Old 11-16-2010, 11:04 PM
jmr's Avatar
jmr jmr is offline
Rep:74
That's good to know thanks.
Old 11-18-2010, 07:42 PM
jmr's Avatar
jmr jmr is offline
Rep:74
Some pics of the front axle skid plate.
Old 11-19-2010, 10:44 AM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:71
latitud will become famous soon enough
nice pic, been thinking about adding skid plates
2010 Dodge Ram, 5.7 Hemi, Crew Cab
Old 11-19-2010, 12:29 PM
Good info and nice pics!
Old 11-20-2010, 10:06 AM
deepblue's Avatar
deepblue deepblue is offline
Trim Level: Quad Cab Sport
Rep:65
deepblue will become famous soon enough
Thanks and nice pics. Those may be in my future.
Build Date: MDH:052720 [May 27th (Thursday), 8PM -- 2010]
2010 RAM Sport - Deep Water Blue, 3.92 Gears, Flowmaster 40 Series, Volant CAI w/PowerCore, BedRug, BakFlip F1, Bilstein B6 HDs
-cc
Old 12-04-2010, 01:19 PM
jmr's Avatar
jmr jmr is offline
Rep:74
Today the project was completed when I installed the transfer case skid plate. The parts needed are skid plate #52022048-AH (same part as the front axle) cost $29.74 a cross member to support it back of the plate #52022046-AE cost was $37.13 with shipping it totaled $79.82. It will take 8 - M8x1.25x30mm bolts 65092333AA to fasten it all together and it was too difficult a task either.
Old 12-04-2010, 03:44 PM
Ram15002ndgen's Avatar
Ram15002ndgen Ram15002ndgen is offline
Vehicle: 97 Ram 1500
Trim Level: Laramie SLT
Rep:55
Ram15002ndgen will become famous soon enough
Dude that bottom is too clean! Do you even drive that thing?
I hadn't seen the underside of the new body. It looks a little hard to service the front pumpkin. Pretty tight squeeze. Good idea on the plates though if you ever plan on taking it off-road.
www.beatcraigslist.com - for posting dangers & secrets
Old 12-04-2010, 05:13 PM
jmr's Avatar
jmr jmr is offline
Rep:74
It's just a baby with only 7,300 miles on it. When I bought it 3 months ago it had 4 miles. I have changed the oil twice so far and it's not too bad to do. The front axle will probably be a bear to change (I'll probably just suck it out of the fill plug).
