Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 11-17-2010, 03:03 AM
Dennyboy's Avatar
Dennyboy Dennyboy is offline
Vehicle: 1999 regular short box sport
Rep:140
Dennyboy will become famous soon enoughDennyboy will become famous soon enough
Default Barely any heat
ok so it's winter and bad things seem to allways happen in the winter. I have barley any heat. it is warmer when sitting at an idle , but not really hot just warm. if i start diving it gets cooler.
I have changed:
water pump
T stat (twice)
fushed the cooling system.
The hoses are all hot. What is weird to me is that the hoses don't have very much pressure in them. I can take the radiator cap off easily with out it spraying out and it doesn' get hot at all even after an hour of driving.
Any ideas?
Dakota County Technical college
Auto Tech apprentice
cataclysmic perverter
If you don't stand behind our troops, PLEASE feel free to stand in front of them.
Old 11-17-2010, 10:06 AM
Resident Technician
Rep:1915
Sounds like you have a bad cap or a leak but I don't see that causing a low heat problem. It's possible you have either a blend door problem or the core could have enough corrosion or fins blocked to reduce the heat output.
Old 11-17-2010, 11:37 AM
Dennyboy's Avatar
Rep:140
ok so were do you think i should start?I really appreciate the help, Ram tech. i'm gunna ask some of the tech's at work today as well just so i can get acouple oppinions.
Old 11-17-2010, 11:54 AM
Resident Technician
Rep:1915
I'd start by using an infared thermometer to check the temps of both heater hoses. If heat is properly transferring from the core to the cabin, then one hose should be significantly cooler than the other.
Old 11-18-2010, 12:31 AM
Dennyboy's Avatar
Rep:140
I don't have access to an infared thermometer but just to the touch they feel prety much the same.
Old 11-18-2010, 12:33 AM
Stainless's Avatar
Stainless Stainless is offline
Vehicle: 2011 Dodge Ram
Color: Bright white
Rep:13
Stainless is on a distinguished road
If no heat is getting to the cabin area and the hoses are hot the heater core must be plugged, or possibly be a blend air door in your hvac assb. I havent seen that much in your year of truck. Ramtech was righto in the first post.
Old 11-19-2010, 12:52 AM
Dennyboy's Avatar
Rep:140
OK update....... we HAVE heat. I didn't think it would work but it did. i let CLR sit for an hour inside of the heater core. then I got my power washer running. I put the one hose in a five gallon bucket and taped the presure hose to the other and hit it full blast. I did that a few times switching sides. I hooked her back up topped off the coolant and walahh We got heat.
Most likely will replace the core this summer but atleast i have heat .
I cooked my hand pretty good which is a down fall but at least i got heat.
