Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Old 11-02-2010, 10:44 PM
Dave Meyers Dave Meyers is offline
Vehicle: 2001 Ram
Color: Very red
Dave Meyers is on a distinguished road
Default A/C Compressor always on with fan?
On my 2001 Ram 1500 Sport, it sounds like the a/c compressor is engaing whenever the blower fan is on, even when not in a/c mode. Could this be the case?
2001 Ram Quad Cab Sport, 5.9
1973 IHC Scout 33's, lifted, fun
Old 11-03-2010, 12:29 AM
moparmanicac's Avatar
moparmanicac moparmanicac is offline
Find em hot leave em wet
Vehicle: 12 RAM 1500 qc 4x4 HEMI
Trim Level: express
Color: bright silver
Rep:204
moparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura about
Im not a mvac tech merely a regular hvac tech (ok so Im still in trade school but I am certified) and this does not sound right, but then again idk how your truck is but on my truck there is no way to have the fan on without a/c or heat going, so do you mean it sounds like the comp. is running while you have it in heat?
[SIGPIC] RIP 02 4.7 Dakota sport qc 4x4
RIP 05 Ram 4.7 rc 4x4
HELLO 12 Ram HEMI qc 4x4 and 94XJ
Old 11-03-2010, 05:41 AM
Vehicle: 2001 Ram
Color: Very red
Yes. I'll pop the hood and watch it run today, then re-post. I believe it's supposed to do so in de-frost mode, to help dry out the air. But it sounds like mine is running even in heat, vent, etc.
Old 11-03-2010, 06:56 AM
The compressor will run in A/C and defrost mode . You'll need to watch the operation of the clutch and report back to us .
Old 11-03-2010, 04:48 PM
GRich's Avatar
GRich GRich is offline
Vehicle: 2005 Dodge Ram 2500 Quad Cab
Rep:117
GRich will become famous soon enoughGRich will become famous soon enough
Mines been doing that where it turns on every 10 sec then shuts off 10 sec even with the heat and A/C off. I thought it was normal!!
Old 11-03-2010, 04:54 PM
Vehicle: 2001 Ram
Color: Very red
I looked at mine under the hood. Compressor not engaged unless on a/c or defrost. Not sure what I heard to make me think it was. I have read about others with the compressor stuck on tho. I don't like the compressor to be on if not necessary, wears it out and drains power. I like power.....I don't know why it would be on in the other positions.
Old 11-03-2010, 05:38 PM
Rep:4105
Tom is right on this and another way to tell without sitting there and watching it, when you park after running the A/C or defrost, you will notice it dripping water under your truck if the compressor has been running, which is normal.
Old 11-03-2010, 09:39 PM
Vehicle: 2001 Ram
Color: Very red
I must have heard some other sensor or relay or something clicking. The a/c works as it should. Now, about that radio.....need to fix the left front spkrs. Shouldn't be rocket science, left rears work, so it must be wires. I ordered a Haynes manual for 17 cents and $4 shipping on Amazon so I can see how to get behind the radio to inspect the wires.
Old 11-08-2010, 01:58 PM
Vehicle: 2001 Ram
Color: Very red
Solved...My a/c compressor runs in the "bilevel" position, even though there is no snowflake indicating that the a/c is activated. I don't know if there ever was a snowflake there and an overzealous detailer removed it, or it was never there. The a/c compressor does not run on vent or floor position, as expected. It would be intersting to know if other folks have a snowflake in bilevel position.
Old 11-16-2010, 06:06 PM
Okiespaniels's Avatar
Trim Level: Fleet
Rep:47
The bi level on my 2000 doesn't have a snowflake, and I'm positive that's factory.
And your compressor runs there, or rather it "cycles" there and on defrost to keep oil circulating through the system.
