Old 11-15-2010, 09:43 PM
TRIPLETED TRIPLETED is offline
Vehicle: 2006 Dodge Mega Cab 5.7 HEMI
Trim Level: SLT 4x4
Color: INFERNO RED
TRIPLETED is on a distinguished road
Angry AC on High lots of noise no flow
When the AC on Max lots of noise very little air flow ?
Old 11-16-2010, 10:02 AM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:78
latitud will become famous soon enough
hvac doors are broken is the likely cause..common failure. Not sure on a 2006 where to even look. Do you get floor and no defrost? What happens when you try to redirect the airflow from say floor to dash to defrost?
2010 Dodge Ram, 5.7 Hemi, Crew Cab
Old 11-16-2010, 10:37 AM
Rep:1909
You have a broken recirc door. I'll bet my hat on it. remove your glovebox and look at the recirc housing while switching from fresh air to recirc and if you don't see the door moving, you've found your problem.
Old 11-18-2010, 12:33 AM
Trim Level: SLT 4x4
Color: INFERNO RED
Defrost works well . Air flow to back pas has a lot of air at the floor mega cab. outside ok but could be better.
Old 11-22-2010, 08:41 PM
Trim Level: SLT 4x4
Color: INFERNO RED
Angry No Defrost Now
Well this morning I started the truck Defrost worked great until I stoppedat a RED light . Now no defrost nomatter were I put the controls air comes from vents no air to defrost . Took advise removed glove box the door . The door for outside - recycle for max door moves the arm for everthing else doesn't move . What is the electrical unit call so I can order new Thanks
Old 11-22-2010, 09:31 PM
latitud's Avatar
Rep:78
actuator is the motor part, there are 3 i beleeve, but the bad news is the one for the floor to defrost requires removing the dash as there is a metal support directly behind the fold down cup holders. Good luck, let us know what you find.
