Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 11-17-2010, 11:16 PM
Terryserf's Avatar
Terryserf Terryserf is offline
Vehicle: 2001 Dodge Ram 1500 Quad LWB
Trim Level: Laramie SLT 4WD
Terryserf is on a distinguished road
Default cracked timing belt cover
The water pump on my 2001 1500 5.9 went out today so I went down got one and proceeded to install. Everything was going great, lining up, bolts were threading by hand.but while I was tightening the bolts the rest of the way I noticed a crack in the timing chain cover anyway, what started as a relatively short project is now a 1 to 2 day project.
My question is now that I have to replace the timing cover, what else should I replace/check while I'm doing this? and is there a previous thread of the process? I could not find anything in the search. I'm thinking... timing chain (duh) the plenum gasket hasn't been replaced yet, the new water pump....... I'd appreciate any tips ,links, etc that would help. Btw I'm no master mechanic but am pretty good with tools...except for cracking timingchain covers Thanks in advance.... The truck has 92,000 miles on it.
If I don't see you in the future..... I'll see you in the pasture....
Old 11-17-2010, 11:28 PM
Are you sure it's cracked and just not a casting imperfection ?
Old 11-17-2010, 11:59 PM
Stainless's Avatar
Stainless Stainless is offline
Vehicle: 2011 Dodge Ram
Color: Bright white
Rep:13
Stainless is on a distinguished road
If it is cracked, remove the timing chain cover, its best to do a oil change as well as coolant can get into the oil(left overs) be carefull of the engine oil pan gasket, its easy to damage. Check to see how loose your timing chain is, if lots of play might as well change it while there.
Old 11-18-2010, 04:24 PM
Terryserf's Avatar
Thanks for the replies.... Yeah, its definitely cracked......What needs to be removed to replace the cover and depending on what needs to be removed, I'd like to replace the thermostat as well. I'm driving my wifes jeep now and am flying out of town on sunday for a week so I'm going to try to make a decision if someone else is going to do it while I'm gone..or..... make time when I get back. Should I just remove the Oil pan and clean it and the pick up while this is being done? Thanks, T
Old 11-26-2010, 12:19 PM
hillbillyclay's Avatar
hillbillyclay hillbillyclay is offline
Vehicle: 2001 Dodge Ram 2500
Trim Level: US Highboy
Color: White Lightning
hillbillyclay is on a distinguished road
I had the same issue after i had replaced the water pump already the i noticed a small leak from the timing chain cover so i had to under go yet another coolant drip. now after changing the timing chain water pump and cover my rad went.... am i the only one who has coolant problems with mopar? my jeeps all did the same thing and my buds 5.9 dakota did the exact same thing.
