Old 11-20-2010, 03:50 PM
MRP's Avatar
MRP MRP is offline
Vehicle: 2010 RAM Sport 4x4
MRP is on a distinguished road
Originally Posted by chithead View Post
Not trying to be mean here, but you might want to research a bit more. The new Hemi heads are essentially 6.1 that are de-tuned just a bit. Same ports for the intake and exhaust, which is why 2003-2008 Hemi intakes and exhaust don't work on these.
Programmer, new air filter and smoother intake pipe (stock air intake is a great design already, just needs a straight pipe instead of the crumpled hose from the box to the throttle body), 180 degree thermostat, and changing out the Y-pipe/muffler is going to be best bang for the buck.
Hey bro, what type of pipe are you going to put on? I've heard a lot about the stock exhaust being just fine (stainless) just a muffler is needed.
Also, on the air box, did you custom build the air tube or is there a place you had ordered it from?
thanks,
Mike
Toms River NJ
Leveling Kit, Power Chip (Diablo), Ridiculous Audio System, Custom Headlights w/ Leds
Old 11-20-2010, 05:39 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
It's going to be a bit before I do anything to my intake. I'm working on a system that uses the factory scoops in the sport hood.
Old 11-20-2010, 05:40 PM
garner's Avatar
garner garner is offline
Trim Level: Lonestar
Rep:46
Is it gonna be mass produced or an one off thing? I would love to have something that uses the scoops
Gone but not forgotten:
First 2011 Ram R/T in Texas
Old 11-21-2010, 10:01 AM
garner's Avatar
Rep:46
So does that mean we can use 6.1 parts like intake manifold and headers?
Edit: Found a kit from moe's that allows use of 6.1 intake manifold
Old 11-21-2010, 10:04 AM
garner's Avatar
Rep:46
So far my mods list is:
Long tube Headers
Cutouts
Mufflers or full exhaust
6.1 intake manifold(is it worth it?) or upgraded 5.7
CAI
Tune
Heads and cams
Better lsd (Truetrac)
Thermostat
Forced induction(maybe)
Tune
Anything else I should add?
Old 11-21-2010, 03:42 PM
Max Power Max Power is offline
Vehicle: 2011 Ram Sport
Color: Deep water Blue
Max Power is on a distinguished road
has anyone done a befor and after dyno with the programmer/ intake/ exhaust. i love the sound and set up with my new truck. Don't think i want to do teh exhaust, but intake and programmer all over it.
Old 11-21-2010, 10:11 PM
chithead's Avatar
Rep:2078
Definitely, good choices with your list above. The main difference with the 6.1 intake are the long runners. They make more HP in the higher RPM band. I am avoiding it because my particular desire is to have gobs of HP and torque down low.
Old 11-24-2010, 11:46 AM
garner's Avatar
Rep:46
Anybody know if they make a supercharger or turbo kit for our trucks yet?
Also I need some exhaust advice, should I go mufflers, catback, straight pipe, or dump the exhaust and have the stock tips mounted in factory position? I would add a cutout on them
Old 11-24-2010, 12:19 PM
chithead's Avatar
Rep:2078
Power adders such as those have been slow to market. I think mostly because of the higher compression ratio of the new Hemi vs. the old. Doesn't take much boost to get in a dangerous area pressure-wise with these engines. I heard Magnuson is working on one... but it's had some delays.
Best bang for the buck on our exhausts seems to be replacing the Y-pipe and muffler. You could dump the exhaust if you like, but then there will be those two cutouts in your factory bumper where the tips were.
Old 11-24-2010, 12:27 PM
garner's Avatar
Rep:46
What's the compression of these motors? And if I dump the exhaust then I'll have the factory tips fabricated in the stock position
