Old 11-18-2010, 10:25 PM
jason3506's Avatar
jason3506 jason3506 is offline
Vehicle: 1999 ram 1500
Color: silver
Rep:19
jason3506 is on a distinguished road
Angry front seal drip drip drip .....
changed my oil couple of weeks back. saw a leak in front seal on engine. now it pours. since the balancer and all has to come off should i go ahead and replace the timing chain? (probally never been done)
Jason
Old 11-18-2010, 10:32 PM
Check the balancer first . Remove it and clean up the sealing surface . See if theres a groove where the seal rides . If there is , this is a swing in the dark , get a balancer repair sleeve . It gets loctited to the snout of the balancer where your seal rides . By installling the repair sleeve you give the seal a new surface to ride on . You may still need to replace the seal . The seal could be damaged or hard .
Old 11-19-2010, 08:31 AM
jason3506's Avatar
Color: silver
Rep:19
Unhappy repair sleeve
so i only need the sleeve if the balancer has a groove where the seal rides correct? what about the timing mechanism? while we are that deep should i replace the chain? thanks
Jason
Old 11-19-2010, 09:53 AM
Rep:1890
You won't actually be inside the timing cover to replace the seal, so you'd be making extra work for yourself.
Old 11-21-2010, 10:52 AM
jason3506's Avatar
Color: silver
Rep:19
Default thanks
ok. thanks for the info. points for you guys.
Jason
