Dodge Ram Decals
Old 11-19-2010, 06:20 PM
Ramathorne Ramathorne is offline
Vehicle: 2013 Dodge Ram 1500 Quad Cab
Color: Mineral Gray
Rep:54
Ramathorne will become famous soon enough
Depending on the time of year I adjust my psi accordingly
I am running 45psi in my 285/65/20 BFG AT TA KO right now
(a bit on the high side for winter as we do occasionally see 10*C here in winter, but it can be as low as -30*C as well...I set them at 45psi when it was 10*C so as the temp drops my psi will be fine)
Old 11-19-2010, 10:53 PM
KTMPRO's Avatar
KTMPRO KTMPRO is offline
Vehicle: 2010 Dodge Ram 1500 Quad cab
KTMPRO is on a distinguished road
I am running nitrogen in my tires, also do it on race machines. I find that it is good at maintaining tire pressures at various temperatures. Its a little more important in racing because tire pressure is crucial when running 5-10psi and they heat up quick. As for the truck - We had 14 degree celcius last week, mid 20's when I got it and am at -12 now. Never seen a difference in pressures and they are at 35 all around. Believe Nitrogen has smaller oxygen molecules thus leaks through the sidewalls at a slower rate. Another benefit is promotes less oxidization and rust than regular air.
Old 11-19-2010, 11:38 PM
Studbuster's Avatar
Studbuster Studbuster is offline
Vehicle: '09 RAM 1500 4dr
Color: Light Graystone Pearl
Rep:61
Studbuster will become famous soon enough
Originally Posted by Swisher View Post
Like I said in a previous thread, after one week I love my truck.
Quick question about tire psi:
Twice in the first week I've turned the truck on in the morning and got a low psi warning. Both mornings were cold, so I was wondering if that's just a normal thing. This morning for instance, by back left tire was at 28 and the others at 30.The first time I noticed the number would go up, but the warning never turned off. I had to fill it up to about 36 before it finally went away.
So, is this just an outside temperature thing, or do I need to have something looked at?
Thanks!
Yes, tire pressure goes down in cold weather. That is why you check your tires when cold and inflate to the factory recomended pressure at that time.
The thing I would check in the above is that one tire is lower than the others and may have a leak. Over inflating is not the answer.
It's my truck and I want it the way I want it!
IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU FIND TIME TO DO IT OVER??
Dave
Old 11-20-2010, 12:59 AM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 1492 Santa Maria
Color: Hot pink
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
Originally Posted by Otterdriver View Post
I can't decide if this is going to be a dumb question or not, but here goes, does it matter if you add regular air to the nitrogen?
Not dumb.
'Regular' air is 78% Nitrogen. Topping off a tire w/regular air won't be a major issue on a 'normal' vehicle.
Old 11-20-2010, 05:12 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2009 SLT MegaCab
Rep:165
Originally Posted by HoustonHemi View Post
Not dumb.
Thanks for that, I didn't think it would matter, figured I would post anyway.
http://i1132.photobucket.com/albums/...62f9145c5d.jpg
STEALTH DELETES/ BUSHWACKER FLARES/ AMERICAN RACING RIMS/ MINI MAX 75 HP TOWING TUNE/ OD TUNE
Old 11-20-2010, 05:53 PM
Resident Technician
Rep:1915
O2 "permeates" approximately 3-4 times faster than does N2 through a typical rubber, as is used in tires, primarily because O2 has a slightly smaller effective molecular size than does N2.
Old 11-27-2010, 12:35 PM
Hoops Hoops is offline
Color: Mineral Gray
Hoops is on a distinguished road
Nitrogen is better for holding tire PSI. Many places charge you for a nitrogen fill. I know Costco uses Nitrogen to fill their tires for free. They'd probably top you off if needed.
Old 01-16-2011, 11:49 PM
03 Hemi's Avatar
03 Hemi 03 Hemi is offline
Vehicle: 2003 Dodge Ram
Color: Blue
Rep:13
03 Hemi is on a distinguished road
Sorry to hijack this thread but I do have a somewhat related question. I recently put 285/70/17's on my '03 Ram QC. It recommends 65 psi on the side wall, but I have friends who run 5-10 psi below what is recommended for better tire wear. Is this true or should I run 65psi?
Josh
2003 Dodge Ram 1500 QC, 5.7 Hemi
Old 01-17-2011, 12:48 AM
Juice420's Avatar
Juice420 Juice420 is offline
Vehicle: 2010 RAM 1500 SLT C.C.
Color: Brilliant Black Pearlcoat
Rep:946
Juice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to beholdJuice420 is a splendid one to behold
Run what is recommended.
Justin
Black Mamba- Flowmaster 40 series, Airaid CAI, 20% tint, GTO taillight covers, ATA nerfs, AVS in-channel ventvisors, Curt hitch receiver, Extang Revolution Tonneau, EZ-down tailgate damper, Recon smoked 3rd brake light, Custom painted engine cover
Black Mamba's Thread
Old 01-17-2011, 12:50 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Read the sidewall carefully. It usually will have the psi associated with a payload.
Brian:
