Old 01-17-2011, 09:29 AM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:71
latitud will become famous soon enough
It recommends 65 psi on the side wall
What Rootbeer said is correct. The inflation pressure printed on the sidewall is the MAX inflation pressure for the MAX load. You can run that if you like, but it will result in a bumpy ride and early tire wear in the center.
2010 Dodge Ram, 5.7 Hemi, Crew Cab
Old 01-17-2011, 09:51 AM
SnowChief SnowChief is offline
Vehicle: Ram 2500 SLT Quad Cab
Rep:147
SnowChief will become famous soon enoughSnowChief will become famous soon enough
I have had the same issue. Also, keep in mind when you add air as to whether your tires are warm or cold - it makes a difference to ensure you get the right psi.
Old 01-17-2011, 12:41 PM
MrPEZO's Avatar
MrPEZO MrPEZO is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x2
Trim Level: Crew Cab Outdoorsman
Rep:38
MrPEZO is on a distinguished road
When I had Nitrogen in the Charger tires, I was told only to put air in it only if I had to and then bring it in for service to purge it and refill.
Yeah the temps stayed steady more (which is the main reason for using it) but other than that I was glad to use regular air again. I have a compressor and its easy enough to just check the PSI and add when needed.
2011 RAM Crew Cab Outdoorsman- Nav, Remote Start, 3.92 Gears, Alpine Stero, Mopar Bed Rug w/RAM Head, Mopar Black Side Steps, Tint, Weather Tech In Channel Vent Visors
2012 Durango RT
2006 Charger RT - Mopar Vent Visors, Daytona Blacked Out Grille, BT Catch Can, Air Hammer CAI-SOLD
Old 01-17-2011, 05:14 PM
03 Hemi's Avatar
03 Hemi 03 Hemi is offline
Vehicle: 2003 Dodge Ram
Color: Blue
Rep:13
03 Hemi is on a distinguished road
Thanks for the help!! I did notice a smoother ride after dropping the pressure a few psi.
Josh
2003 Dodge Ram 1500 QC, 5.7 Hemi
