Taillight issues, 1987 power ram 318 auto - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 11-19-2010, 09:36 PM
geod919's Avatar
geod919 geod919 is offline
Vehicle: 1987 Dodge Power Ram
Trim Level: The idk level
Color: gunmetal
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
geod919 is on a distinguished road
Default Taillight issues, 1987 power ram 318 auto
Alright. I'm not getting any operation out of my tails at all. my license plate lights do work. I can't find anywhere that the wires are grounding out or anything, but when I have the lights on, my battery is definitely drained much more quickly than the alternator can fix.
Reverse lights work sporadically.
marker lights do not work.
turn signals do not work.
Brake lights work when reverse lights work.
license plat lights always work.
Now, I've gotten under there and looked, and even soldered a couple of spots that looked bad. But I'm still having the same issues. the only thing I can see doing it might be where the previous owner spliced in wiring for trailer brakes (with in line splice connectors) or where he hacked up the license plate lights. would rusty bulb housings cause all of this discharge?
Just looking to be pointed in the right direction, maybe a nice wiring diagram or something.
Old 11-20-2010, 06:51 PM
Resident Technician
Rep:1915
Start by getting the wiring put back stock, cleaning out or replacing the bulb sockets, making sure the grounds are good and checking the headlight switch itself.
Old 03-21-2011, 11:04 PM
Thunder38843 Thunder38843 is offline
Vehicle: 1987 Dodge Ram 4x4
Trim Level: No Idea
Color: 2 tone - Brown and Tan
Rep:13
Thunder38843 is on a distinguished road
I recently had this same problem. I installed a new stereo and grounded it to the ground wire on the original wiring harness. BIG NO NO! After I did that and got the stereo playing great, I had no tail lights. Came in the house and googled it and foundout that you can't do that on a Dodge. Ground wire has to be attached to the chassis. After rewiring as the website explained, I had tail lights again. Weird, but true.
Old 03-25-2011, 10:19 PM
OKMIC1 OKMIC1 is offline
Vehicle: 1986 Dodge Ram 4x4
Color: camo
OKMIC1 is on a distinguished road
I'm glad I read this since I'm planning on changing out the stereo.
