Dodge Ram Decals
Old 11-19-2010, 10:27 PM
battlerattle's Avatar
Vehicle: 2016 Ram 2500 Laramie LongHorn
Trim Level: Laramie LongHorn
Color: Granite
Rep:286
Unhappy Toyo Open Country M/T Questions
So I tried the search function and like most VBulletin Boards it sucks. Feel free to harass me and point me in the right direction if this has been covered.
I just had 33/12.50R20 Toyo Open Country M/Ts put on my 2010 Ram 4x4. I put on the Daystar 2.5"F 1"R lift/leveling kit at the same time and had an alignment done.
Well, now I have a right hand pull. After much search it seems to be a fairly common problem. Has anyone alse dealt with this? More importantly, is there a fix?
Just Got it, Give me time!
Old 11-19-2010, 11:46 PM
Color: Granite
Rep:286
In case anyone is wondering, this is how they look. I rather like it, just the damned pull.
Old 11-20-2010, 02:30 AM
Rep:3322
They look great, and I'd want to keep them to, so just a few of the 'dumb' things to check first... like tire pressure, or possibly sticking caliper. An issues may be the alignment, have a look at the numbers, also, rotate the tires and see if that cures the problem... if not, then it's an alignment issue, not a tire issue.
Old 11-20-2010, 07:30 AM
Color: Granite
Rep:286
Alignment was done at the same time the tires were installed, numbers are all litterallly right on factory spec. I have double and triple checked the pressure and rotated the tires three times. No brake drag (good guess and what I thought too initially after rotation didnt work). I even had a second facility confirm the alignment.
I know its the tires after alot of research. Seems to actually be quite a common issue that even Toyo is aware of. My biggest question is has anyone come up with a fix, especially with the IFS front end. Were the Ram a solid axle like the Jeep it would be a rother easy fix.
Old 11-21-2010, 01:56 AM
pstern's Avatar
pstern pstern is offline
Vehicle: 2010 Ram 1500
Trim Level: SLT Sport Premium
Color: Mineral Gray
Rep:76
pstern will become famous soon enough
2010 RAM 1500 Sport
I have a 2 inch rough country lvl kit
Same Toyo's 295/70R/17 and I do not have any pull issues
Old 11-21-2010, 07:21 AM
Swap the tire on the front , from side to side , and tell us what it does then . Can you post up your alignment ?
Old 11-21-2010, 11:22 AM
Color: Granite
Rep:286
Already swapped, and with the rear front to back and side to side. At this point every tire has been in every posittion. Still pulls to the right.
I dont have the alignment print out, i must have misplaced it. I will have them print another one next time I am in the area.
As an example. Computer said factory toe needs to be between .01 and .02 degrees. Mine was able to be set to .015, literaly dead center of factory spec. Same with camber, caster. I just dont have all the numbers off the top my head.
