Loud clicking @ 20-30mph "no-load" coast - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 11-19-2010, 11:19 PM
REDRAMMER's Avatar
REDRAMMER REDRAMMER is offline
Vehicle: 2008 Dodge Ram Quad Cab 4x4
REDRAMMER is on a distinguished road
Default Loud clicking @ 20-30mph "no-load" coast
Hello All, I think I have a unique situation with my '08 1500 Quad Cab HEMI of which I hadn't found on previous threads. Apparently I am having a loud clicking (NOT the perverbial HEMI tick) under the truck when I am coasting at 20-30 mph. Particularly or more to the point. . .I excel to speed (25-30mph) after turning onto a residential street. I then let off the excelerator to a no-load coast. Loud clicking begins. I drop the automatic tranny down to "2" and the clicking goes away. At "D" coast speed I am at roughly 900-1000rpm, at "2" she goes to about 1600-1700rpm. I am thinking tranny or exhaust. Has anyone had or heard of this problem? Any suggestions or input would be greatly appreciated.
Old 11-20-2010, 02:41 PM
Resident Technician
Rep:1915
Pull your drive shafts and check the u-joints for binding or any other signs of the bearings in the caps going bad.
Old 11-20-2010, 05:33 PM
REDRAMMER's Avatar
Thanks RamTech, You the MAN!! Sounds like if anyone would would know these things. . .you would. I recently bought my baby at the USED lot at a Suzuki dealership and wanted to walk in there with at least a suggestion of what it may be considering these guys are probably more familiar with the aforementioned brand. The work will be done under their usual 3mos/3000mi "Certified Used Vehicle" warranty. Thanks again RAMTech.
Old 11-20-2010, 05:34 PM
Resident Technician
Rep:1915
Let us know how it turns out.
Old 02-17-2013, 01:12 AM
REDRAMMER's Avatar
Default Finally back!
Well . . .I am finally back. Sorry I have not been here lately. Been busy with life but its been good so far. Anyway, I took my truck to a local Dodge dealer instead of the "other dealer" I bought from. Reasoning told me they would know better than the other guy. The initial diagnosis was the transmission cylinoid was bad making the ratcheting noise. So they practically rebuilt the lower half of the tranny with new fluids, filter and cylinoid, etc. Guess what? After a $100 deductible later, STILL CLICKING at "no load" coast. Took her back and they did a closer look. The culprit wound up being a loose retainer/ tensioner for the chain than engages the MDS (multi displacement system-the system that shuts down 4 cylinders under low loads on the newer HEMIs). So, they practically had to rebuild the entire front end of the engine to replace that thing considering it is mounted behind the water pump and in front of and driven from the engine crank. Needless to say, the warranty covered this also with my expenses being just for fluids. The dealer ate the copay. In summary: I got a lower tranny rebuild w/ new cylinoid, filter and fluids. A rebuild of the front end of the HEMI. Total cost: $1954. My cost: $100 copay + $94 for fluids. Dealer cost: $100 copay for their misdiagnosis. Warranty covered the balance. I bought the extended warranty 2 mos. prior for $1400. I am a BIG fan of those warranties now.
Old 03-14-2015, 01:35 PM
AmericanHemi AmericanHemi is offline
Vehicle: 2010 Ram 1500 2wd 4dr
Trim Level: ThunderRoad
AmericanHemi is on a distinguished road
So glad I found this post. Mine just started doing the exact same thing this week. I was getting nervous but now...dealership, here I come. Thanks for the info!
Old 10-23-2015, 06:04 PM
SSCharged SSCharged is offline
Vehicle: 2012 Dodge Ram Sport
Color: Deep Cherry Red
Rep:19
SSCharged is on a distinguished road
Could be the issue on mine too, I'm getting the exact same noises, and when it seems the truck is changing over to get more power it starts to do it too.
